nevgriff64 wrote:Very, very nice Auto and congratulations on the new bike..
Did you manage to take it out today and if so, what are your thoughts on it?? Advantages/disadvantages between the 2 stroke and the 4??
Hi Nev,
Keeping in mind these are the ramblings of an unfit novice with about 2 months experience..... also keep in mind the 290 Cabestany was quite highly strung and not regarded as a learners bike as far as power delivery etc went.
Two completely different bikes, not bad/good, just different, with the 4T being much more like the bike bore enduros as far as power delivery and use of controls go.
The 4T is much easier to ride smooth slowly.
4T is slightly heavier top and front, but not significantly in a noncompetitive novice kinda way.
4T tends to stall dead like the big 950/990 if you get it wrong, none of this down to zero rpm then recover like the 2T's do.
Engine respone is slightly different, probably due to more mass on the 4T, but I did not take long to get used to it.
Engine braking on the 4T is throttle controlled due to the low gearing, let go of the throttle and the back wheel slows, or locks up with the engine pretty much instantly.
With the 2T I found you tend to apply throttle first to get the revs up, then regulate the clutch to control your launch....with the 4T I tend to use more throttle control, but cover the clutch.
I can't really hop either wheel properly, but seem to be just as good, if not better on the 4T as I was on the 2T.
I can see it not being too long before get it wrong and grab a handful of the torque and traction sending the bike up and over some obstacle... without me attached.... it is very capable in that aspect.
To my mind, I think the 4T is better for my intention of improving my skills on the 990 as the two bikes respond similarly.. even if one is about 130 kgs heavier and has probably 80 more Hp.
Maintenance will be a little more complex, but valves don't need doing very often and oil change is straight forward enough (I did one for the hell of it).
I like the no smoke, no premix and smooth quiet idle, but it can be a bit of a shit to start until you find the technique.
