Suzuki RL250 Mania
Westy
Re: Suzuki RL250 Exacta Mania
Post by Westy »
Shiney!
30 minutes with 400 grit W&D, 30 minutes with 600 grit W&D, (I'll add another 30 minutes of 1000 W&D), Decent once over with Brasso, Decent once over with Mothers Mag and Aluminium Polish and a Dremel with a flexi-drive and polishing wheel (It saves your finger).
Is it time to ride yet?
If there is any oxide present, starting out with a genuine 3M scotchbrite scourer soaked in aluminium de-oxidising cleaner reduces the wet-and-dry workload by a factor of 10.
Another point is that jap aluminium is often coated with clear laquer, so using paint remover before the de-oxidising step will save lots of hard labour too, if there is any lacquer left. Common items coated with lacquer from new on jap trials bikes are engine covers, fork sliders, wheel rims and triple clamps.
Westy
Post by Westy »
Hey Dave,
Thanks for the tip. The covers didn't have any clear left but the front shocks do.
Is there a particular name or brand of oxide cleaner I should grab?
By the way, do you think it might be worth chucking some molasses in my steel tank? If so, where would I get the wonderful black goup from?
Maybe if I buy some Krispy Kremes, chuck em in a blender and pour the slop into my tank it could possibly have the same effect?
Westy
Westy wrote:Hey Dave,
Westy
Whatever brand your local paint shop stocks. Up here it is Septone brand.
Wherever your local primary producers buy their farm supplies from
Yes - good idea - and see if the motor will run on it while you are at it
trialsmutha
Bike: all bikes
Re: Suzuki RL250 Mania
Post by trialsmutha »
ive had good results with natual anodizing on fork legs,rims and tripple clamps after polishing, if you want that factory look! If its a high polished finish you like, but dont like the idea of constantly re-pollishing you can clear powder coat it, you lose around 5% of the shine. but it lasts for years.
garrison
Bike: KT250
Post by garrison »
Westy wrote:...
Westy
Don't do it! a russian town was wiped from the map in the 60's when a local tried something similar with yak fat (KK donuts are 120% synth-yak-fat) in his Ural.
Molasses is $2.50/litre at the local horse supplies joint. Take your own bottle. :wink:
garrison wrote:
Westy wrote:...
Westy
Yeah it's not bad on toast too and much cheaper than at the supermarket.
Westy
Post by Westy »
Hey Trialsmo. I like the anodising idea. I find polishing relaxing but if it cuts into my riding time well, that's something else. I'll look into it. There are a few powder coaters in town too. My bike has alloy Takasago's on it as original gear. I suppose i'd have to take them off the hub to get them anodised. Then if I am going to do that, new excel's are only $270 each last time I bought some anyway. Hmmm there's some thought there.
Westy
Post by Westy »
I got more parts in the post today. The ferry finally crossed the Murray and I got my PE250 sprockets. Yesss! I tell ya. That 11 tooth sprocket is gonna me the bike go unbelievably slow.
It's slow already with the 15 and 50. 50/15=3.333 and 50/11=4.545454.
So if I am correct,
    1st , 36.234:1 (36.234)(3.333) = 120.768
    2nd , 26.996:1 (26.996)(3.333) = 89.985
    3rd , 24.161:1 (24.161)(3.333) = 80.529
    4th , 12.943:1 (12.943)(3.333) = 43.139
    5th , 9.599:1 (9.599)(3.333) = 31.993
and
    1st , 36.234:1 (36.234)(4.545) = 164.684
    2nd , 26.996:1 (26.996)(4.545) = 122.697
    3rd , 24.161:1 (24.161)(4.545) = 109.812
    4th , 12.943:1 (12.943)(4.545) = 58.826
    5th , 9.599:1 (9.599)(4.545) = 43.627
Where would these ratios be good?
Westy
Post by Westy »
Righto trialers,
I need some advice. I got a quote to grit blast my frame. I am having difficulty trying to decide if I want to powdercoat or 2pac the frame of the RL.
Powdercoaters say PC is better. Sprayers say painting is better.
If I paint the frame I'll do it myself because I like painting.
I want the frame to be metallic silver. What do you say?
