Honda TLR
keychange
Re: Honda TLR
I have removed the front sprocket which is very lose - not on the drive direction but left to right across the engine. I have what I thought was a details owners manual but I can't find a diagram of the drive sprocket so resort to CMS.nl exloded view of Reflex 200 86 model (see below) and its completely different to what is currently on my bike - refer pictures below - my sprocket has no fixing plate and no oil seal on the drive side - in fact the sprocket is held on with a rather flimsy circlip - surely that's not right. I can see the holes for the fixing plate but I can't figure what the plate does what is it fixing to - how does it hold the sprocket onto the spline?
- drivesprocket.JPG (30.39 KiB) Viewed 6372 times
- counterspr.jpg (45.7 KiB) Viewed 6372 times
Re: Honda TLR
The bracket is fixed with two 6mm bolts with blind heads. either drill a small hole and use a screw extractor or just create a slot in the head of the bolt and screw it out with a flat blade.
keychange
Re: Honda TLR
I found this at http://www.tytrials.co.uk/trailandtrial ... TL125.html - so it appears to be correct but mine doesn't have the washer thus the excess movement
For fitting Talon front sprocket which has a shoulder so cannot accept the bolt on tab.
Washer goes behind the sprocket with the circlip at the front.
For all years & models of Honda TLR200 including Reflex
- circlip.JPG (28.48 KiB) Viewed 6321 times
keychange
Re: Honda TLR
keychange wrote:Last Monday I ordered an idle jet , fork seals and chain tension block form CMS in Netherlands they now advise dispatch date should be 13th September
Can anyone suggest an alternative reliable source for these and other parts
Andrew
Well I have started reassembling and I think it will end up looking quite reasonable (not concourse by a long shot) I have everything I need except for the few things from CMS !!! - very frustrating given I ordered them a month ago. I bought an another idle jet ( jet kit ) from USA ordered 1st of Sept and it arrived today - the Dutch have much to answer for.
Re: Honda TLR
Reminds me of the line from one of the Austin Powers movies:
"There are only 2 things I hate, intolerant people....and the Dutch".
Shaun B
Shaun B
keychange
Re: Honda TLR
Shaun
Yes Austin and I have a lot in common - I shink the dutsch are foin in shmall doshes - very, very shmall doshes.
UPDATE - Literally as I was writing this post I heard our mailman pull up outside - he drives like a maniac and usually the exhaust is hanging off so it's easy to tell when he's coming .... and sure enough my parts from the wonderful Nederlands have arrived - now off to the shed and get this thing assembled :)
keychange
Re: Honda TLR
Turns out the seals I ordered from CMS are dust seals - their parts view is ambiguous. Would have been nice if someone could have told me the oil seals are freely available here
keychange
Re: Honda TLR
It's 90% reassembled I just have to connect the brakes and front mudguard - it looks better than it did.
Alas no spark
There is power to the coil fluctuates up 18volts - but nothing coming out. Ross Brown lent me a Clymer manual and it has colour wiring diagrams. I am not reinstalling the lights so I haven't connected the regulator - I have tried wiring it as per the no lights diagram and as per original but no spark. The Clymer resistance test for the coil is very ambiguous does anyone have a simple fool proof test that I can do ( I have a decent multimeter)
Alas no spark
keychange
Re: Honda TLR
One of my son's was coming to visit from Brisbane so last 48 hours have been full on to get the TLR back together - I gave up worrying about the spark and just assembled it , filled it with fuel and first kick away she went - purring - its sooo quiet. Carbie kept flooding - isn't it great being able to remove float bowl and adjust float level without removing the carbie. Anyway this afternoon we were able to go for ride - my Monty did it its high idle stuff but apart from that went fine. The TLR went like a dream although the the back brake is non-existant and the suspension is much too firm - I might let the air out of the forks. I have two manuals and neither agree as to fork oil capacity - I used 190cc - any advice on this would be appreciated.
The final assembly was a bit rushed so I will tidy everything up and post some pics soon - but I am delighted with my new toy.
keychange
Re: Honda TLR Carbie Overflow
One quick question - the carbie floods when I put the bike on side stand - it is fine when level. I have adjusted float twice and there is isn't much adjustment left - is there something else I should be looking at ?
