Hi all, got a problem with the forks on my ty always going thru seals on a regluar basis, like three to four times a year.
i've trird genuine and non genuine seals and no change.
is there hope out there ?
Shawn.
(dont PM)
95' Ty fork seals
Shawn James
- Bike: Sherco 2012,TY Pinky
95' Ty fork seals
Shawn from T-bar {Toowoomba}
Re: 95' Ty fork seals
Both fork tubes or just one?
Leaking around seal seat or past lips?
Seal staying in place or moving?
Damage to surface of tubes?
Unusual type of fork oil?
Too much fork oil?
How much riding is 1/4 of a year?
Is it a TY250Z?
Are they standard forks?
Too much fork oil?
Is it a TY250Z?
Shawn James
Hi David,
Sorry about the late reply, been a fair few thing happening in the last month.
Yes both fork seals, not both at the same time tho
yes around the seal itself
yes the seals are in place
no the tubes are fine
running a 5 weight oil
amount to spec as per manual
less than once a month use
yes its a tyz
yes there standard.
i hope this will do!
Shawn.
yes its a tyz
yes there standard.
Shawn.
Shawn - the genuine fork seals you tried. What did they have written on them and what was written on the aftermarket seals you tried?
Shawn, the quick easy solution is to remove the small springs out of the fork seal and reduce the length of them by 3 mm's, then replace back in fork seal. It is a bit tricky to find the joint in the spring. Cut the female side of the joiner. Hope this helps.
Shawn James
David, i'm not sure, if you mean size numbers, the first few times it was just ask over the counter, quoted make and model they pulled them off the shelf for him.
Shawn
Shawn
No I mean what brands were the seals markeds with.
Shawn James
I cant rightly remember, some were factory and others non factory.
Shawn
Shawn
