Thanks Guys,
@Sherpa - took end box off no change - checked mid box no blockage.
@Geoff - just checked flywheel key its fine. No CZ motor but I thought they were pretty reliable??? Least I know my flywheel puller works.
Induction thing may be probable. The disk was actually refitted one tooth different and it ran beautifully until this event. I believe for a very small time it started sweet and then went pear shape so the whole "it must have happened in transit" may be a furphy.
Seems unlikely now to be fuel or ignition [it will actually idles quite well and it doesn't stall under throttle] but it sounds like there is a rag in the airbox so maybe the induction disk is the next step as Tricub suggested. And fortunately I have another motor for bits.
The following is a quick video of it running - the throttle was opened at on the ninth second of the clip and it then ran out of fuel as the tank wasn't connected. Big throtlle openings are simply met with more induction noise and no big increase in revs.
https://www.facebook.com/video/video.php?v=10150996090729243&oid=251035327372On Feet up funs [ thanks again for help Dave] suggestion I ran it for at least 7 minutes to see if it was fuel in the cases and I also undid bolt to expel any excess fuel. No change. Checked tank for water - no problems there.
Thanks everyone - at least I'm learning more about how these things may or may not run - will investigate rotary valve next.
