Replacement Motoplat Coil
keychange
Bike: TLR/Cota247
Post by keychange »
Hi my 247's coil is dead - voltage in nothing out ( tested with condensor removed ). I have seen Sammy Millers offering and read several comments about Chinese replacements, does anyone have a brand name or supplier suggestion in Australia.
TriCub
Bike: Triumph
Re: Replacement Motoplat Coil
Post by TriCub »
Are you sure there is nothing going in.
It is far more common to fail the bottom coil or have something go wrong with the points.
Have you done a resistance check of the coil with it disconnected?
Any motorcyle coil that is meant for a points magneto system will work. Your local bike shop should be able to get you a generic coil.
The local bike shop here sells MCS brand HT coils over the counter that work fine on my Bultaco M49 and also on a friend's TY175
This is what they look like
keychange
Bike: TLR/Cota247
Post by keychange »
Thanks David that looks like what I am after
