If you want to identify what model the black Sherpa is, compare the pics below.
Kombivan wrote:
Here is a factory brochure of the '74 Sherpa. (Altho this is the 325 the 250 was visually the same apart from barrell & head.)
- SherpaT '74.jpg (104.9 KiB) Viewed 23092 times
You can see both the central vertical down-tube still there & the Y-section tubes as well.
Here's the 250 version, tho with the diff tank for the UK market:
- bultaco sherpa t 250 m124.jpg (162 KiB) Viewed 23092 times
Here is the first of the models with the new generation frame - the '75 brochure (The production version was 1st available in late '75 after being shown at the Barcelona Motor-show):
- Sherpa T-75 brochure.jpg (70.13 KiB) Viewed 23092 times
If you look carefully you can see that this model has a very diff frame to the black bike, even if at 1st glance it looks somewhat alike.
