Very pretty! I'll be expecting to see those flowery decorations on it on Sunday too.chippy wrote: .....KT tank and side covers painted, just in time for the Queensland Titles this weekend......
- Bike: TY175, OSSA MAR
Please someone take some photos of Chippy's KT with that tank on it before it gets ridden at Rockatoo
The disappointment of not seeing the flowers was more than made up for by seeing a nice old twinshock with a pretty green tank and side covers, being ridden very well, at least in the section where I was observing. I’m pretty sure someone somewhere has photos. There were lots of cameras around.
When I last looked, the scoreboard indicated that there were several riders very close to the lead in twinshock, and in all probability a good ride or a bad ride in any given section on day two could see any of a few riders take the lead. I’m not sure that a pretty petrol tank is enough to make that difference.
Re: Basket Cases Abbey and Donna TL 125 Challenge
[marq=left][/marq]Hi Everyone,
Team Hardwood ventured down to Denman this weekend for their 2 day Trial and what a great weekend it was, Twinshocks everywhere! The sections were superb with an excellent selection of diverse lines, almost as diverse as the bikes
There was even an all Girl Honda TL 125 Challenge, Abbey and Donna had a good close competition on pretty much identical bikes.
Thankyou to the Denman Club for an excellent weekend, we can't wait for the 2 DAY NSW Classic and Post Classic Championships
Greg did Abbey's Dad tell you any stories about that TL125?
David Lahey wrote:Greg did Abbey's Dad tell you any stories about that TL125?
David, like most old bikes the TL has a few Battlescars and if it could talk there would definitely be a few stories. Something tells me they may vary from John's version of events
chippy wrote:Hello everyone,
We are getting a bit off track here from basket cases with these "nuts".
Chippy,
Think I have found your LOST NUTS
rear axle. 12mm axle in the rear with the tiny 32mm x 12mm bearings so far in from the swingarm, what were they thinking? They have used 3 bearings with 2 on the sprocket side, but the bending moment is too far from the support of the swingarm. Your secondhand sprocket adapter has worked out well, with a little tweak in the lathe, it now has an extra 32mm x 20mm bearing the runs and spreads the load on the hardened spacer. We are probably best off machining up another one for your
350?In your Plethora of
parts, do you have 520 10T or 11T front sprockets?2017 Newsflash: RUST IS THE NEW BLING !
Hi everyone,
With the Queensland titles done and good rides by Glen Chadwick and James Wager with me third on the
KT, it would have been interesting with you in the mix Greg. I even had some plant decoration on the
KT for Mark's benefit. David I didn't even scratch the new paintwork on the tank!!
Gee Greg the rear axle is bent on that
, it looks as though it's the shape of a banana.
I didn't realise it was that bent. I will definitely need a spacer for the
350 so that the same thing doesn't happen. Greg I know you like low gearing on your bikes, can you tell me how many teeth on that rear sprocket? I don't have a front 10 or 11 tooth sprocket, but I'll get you one when I order more parts. I think the standard dished rear sprocket I have (same as in the photo) is 42 tooth and i will run an 11 tooth on the front as you know I prefer to have a slightly taller first gear. I think David likes a really low first gear on his
Greg I am still short a nut, as I need a front axle nut and like you said is the same for the rear axle. It's a 12 x 1.5 possibly.
Chippy
KT for Mark's benefit. David I didn't even scratch the new paintwork on the tank!! Gee Greg the rear axle is bent on that
.Greg I am still short a nut, as I need a front axle nut and like you said is the same for the rear axle. It's a 12 x 1.5 possibly.
Chippy
chippy wrote:Hi everyone,
Gee Greg the rear axle is bent on that, it looks as though it's the shape of a banana.
Chippy
Good to hear the KT tank is as-yet undamaged Chippy. I'm hoping you are coming up to ride at the CQTC Turkey Beach trial with it so I can get some nice photos. Were you happy with how the KT went at the Qld titles? I've fiddled the suspension at both ends on mine quite a bit since you last rode it (after being able to study it with you riding) and am very happy with how it goes.
I'm glad you mentioned the banana-shaped OSSA axle in Greg's photo. Until then I couldn't quite work out what that photo was about, except that coming from Coff's Harbour, I though it was just another "banana-bender" Greg joke photo.
Hi everyone,
David yes I am bringing the
KT to ride the round being held by CQTC so you can get some photos. I'm glad I could help with your suspension set up on your
KT David. I wonder how different it will be to mine?
I did notice straight away, but did anyone happen to see the Ossa symbol in the photos that Greg created?
Chippy
KT David. I wonder how different it will be to mine?I did notice straight away, but did anyone happen to see the Ossa symbol in the photos that Greg created?
Chippy
Greg always puts hidden tricky things in his photos, and no I didn't see it till you said it. He is just trying to stir up the OSSA train spotters who spend their lives explaining that the OSSA symbol is actually not a 4 leaf clover
