Just picked up myself a 2010 Beta EVO 125 and I'm finding it hard to get my head around the clutch engagement. I will be popping the clutch cover off tomorrow to have a look at the quality & thickness of the clutch plates but has anyone ran across the same issue? The clutch feels like a light switch. I've ridden a Scorpa 125 and an old Gas Gas 270 before and they were smooth as butter compared to this.
I've read on other forums that there is a mod which includes filing down glue and flattening our surfaces of the plates, others have talked about replacing the clutch with a new smoother kit from Beta. Anyone have experience with this?
Edit: I also noticed this problem with both a slow & now my new fast action throttle.
Edit: This is now solved (read my latest post), Big thanks to Paul from thehellteam.com and David Ryan from Beta Australia for their help
Regards,
The rotational position of my throttle tube was too far forward which was causing me to be on the throttle more than I should (think revving the bike and trying to smoothly engage the clutch) Even the smoothest clutch would feel grabby with too many revs. Also the other issue was the bike had the optional 2 thicker clutch plates (outer most/inner most) installed which supposedly gives it more grab to the end of the clutch stroke, as the clutch stack was pretty much brand new I replaced these two out with the standard plates. Combined with also dropping the idle RPM to around 950-1000 the bike is smooth as butter!
