David Lahey wrote:The OSSA MAR 250 design presents quite a few opportunities for head-scratching if you look closely. I reckon if you wanted to write an amusing book for people who like old dirt bikes, showing the weird and oddball design ideas seen on 1970s bikes would be a great subject.
The MK1 MAR has a couple of weird, unhelpful things that were fixed by the time the MAR Mk 2 came out. Can anyone suggest what they were?
David, the more that I look at the
, the more weird things that I find, for example behind the front sprocket which is on the
Right Hand Side tucked away just above the bashplate is a different location for a gear lever
So to answer your question, my guess is the
MAR Mk 1 had the brakes
ON THE WRONG SIDE
David Lahey wrote:re the brakes having excessive spring return, I took off the return spring that was on the brake camshaft (on the outside surface of the brake plate) and it lightened it up. Your idea had me thinking that maybe you could fit a spring to the chain tensioner that went to the swingarm rather than the brake shaft, and remove the spring that twists the brake shaft upwards
My thoughts were similar, but the rear brake cable drags a little and needs the brake cam return spring. Also thought removing the main (dual purpose) spring and starting again, however the chain tensioner pivots on the brake pedal arm and not on the swingarm, so the extra helper spring for the rear brake was an easier solution.
David Lahey wrote:I did some more work on the
MAR today and thought that it might be fun to see if anyone can come up with logical (or not-so-logical) reasons for some of the the bizarre design features they used.
There are quite a few things that are a bit weird, but I thought I might start with the finning on the crankcase. I took this photo with the bashplate removed to show the fins better
Any ideas?
Fantic use a similar design and I think the fins are all about surface area for cooling. Volkswagon drivers understand this really well.
![images[2].jpg](./download/file.php?id=14667&sid=702d11118cc16cf1573fb83d7f9f9d80)
- images[2].jpg (42.24 KiB) Viewed 5314 times
Kombivan wrote:Having those fins there would keep the fuel cool prior to entering the combustion chamber thus when the fuel is ignited it would expand at a more rapid rate than if hotter. bit of a comparison would be driving at night compared with driving in the day at night the vehicle always goes faster and performs better.
Guy53 wrote:For a shorter rider, I can see the benefit of a kick starter that engage '' late '' it give more leverage.
Guy, If you have not started an
before, the load starts at a lower than some other bikes level, which also happens to give more force. Because the kickstart drives through the clutch and therefore the primary drive (which seems quite a low ratio) means more revolutions of the crank per kick. It also means the clutch has to be out for starting.
