I bought this bike nearly 3 months ago with the intention of buying a cheapish trials bike to learn some new skills on. I knew that the forks needed work, but I was hoping to get away with about $600- worth of repairs and go riding.
It didn't turn out that way.
Every bolt that I've touched was either loose or seized. Most of the bearings were dry, full of rust and worn out.
The spokes were loose and the threads seized so that they couldn't be adjusted.
Wheel bearings were dry and worn out.
When I removed the airbox, I found that the manifold connecting the carb to the airbox was perished and cracked, not all the way through so as to allow dust to bypass the air filter, but not far off.
The bottom line is that I should have been more patient and waited for a better bike to come along. At least now I know that this one is ready to ride and should be a good thing.
It wasn't all bad. I've learned the bike's history and the owner before the guy I purchased it from was very fussy and had done a lot of work to it, including rebuilding the engine with an oversized piston, fitting the fat bars and some of the S3 bling as well as the Cabastany graphics kit. The motor seems very sound with strong compression and no rattles.
This is how it looked the day I picked it up.
I should have walked away then and there.
