Techo's please give me some advice.. I have just had to get a new clutch cover gasket to fix a small leak in my Beta.
Question is: Metal gaskets.. Do they require sealant?
Thanks in advance :)
Craig.
Clutch Cover Gasket?
Re: Clutch Cover Gasket?
Not sure what you are asking because I'm pretty sure the clutch cover gasket on a Beta should not be metal
Craigus77
- Bike: REV3 200
The one I took off that was leaking was paper.. New one sent from Dave @ Beta Melbourne is metal. Changed design and are meant to be a big improvement on the originals.
Because those surfaces are rarely perfectly flat and smooth, use a sealant, but a sealant that will allow you to take it off again later (Loctite Master Gasket is suitable)
I'm pretty interested in why a metal gasket was needed there
- TRIALTECH
- Dealer
- Bike: Beta Scorpa Sherco
guys
Its a reusable one with a sealing material bonded on both sides..should outlast the bike..the paper one was a PITA
Denis
Denis
TRIALTECHMOTO
New and Used bikes
Spares and Accessories
[email protected]
http://www.ttmoto.com.au
0491.075.653
New and Used bikes
[email protected]
0491.075.653
