Montesa Cota123 Early 80's
36Cycles
Bike: Montesa Cota123
Re: Montesa Cota123 Early 80's
Post by 36Cycles »
Thanks to the heaps of awesome people out there offering heaps of great information, still trying to get the bottom of this Oil Quantity issue with some certainty.
I have learnt that some Montesa Cota's had two seperate places for oil, and some have a combined, I am reasonably comfortable that mine is a combined as I can only find one fill point as in photos. So I am assuming if you have two places to put oil then the quantity required would be 600ml which seems like the Older Red tank Cota123. If you have latter model Cota123 White tank like Cota200 then you should be using combined quantity of 900ml.
Ahhhhh.... The joys of owning an uncommon bike make the answers so much more rewarding.
Brigalow
Bike: montesa,beta,DR
Post by Brigalow »
Had the same sort of issue a bit with my 172, 900ml seems to work fine in it.
36Cycles
Post by 36Cycles »
Information from 29MarkT on Trials Central;
Oil Quantity
900ml's 1982 Cota123/200 share same bottom ends.
Air Filter
Same as 200, which now have a European Link for.
Fuel Ratio
3-4%
Next Jobs;
Oil Change, and fit Genuine Montesa Bash Plate, scored 3 of these in an eBay Auction
Clean out Carby
Repair some bad electrical wiring
Next challenges;
Chain Tensioner
Mikuni Carb
Will post Specs page next
36Cycles
Post by 36Cycles »
1982 COTA123/200 Quantities
36Cycles
Post by 36Cycles »
I have just had additional confirmation from Jared Bates from South West Montesa;
The correct amount is 900 cc. (30.5 ounces) clutch and gearbox are combined on this model.
36Cycles
Post by 36Cycles »
Oil Quantity sorted, now I'm getting my head around what is the best Spark Plug to use!
Bike came with NGK B9ES
Manual States Champion N4, NGK equivalent is B7ES
Would there be a reason that someone would change the type of Spark Plug to reflect a different climate, Australian or maybe changed for different riding style than Trials.
I have broken down the NGK Spark Plug code below,
B: Thread Diameter, 14mm
7: Heat Rating, lower is more Hot
E: Thread Reach, 19mm
S: Standard 2.5mm Centre Electrode
What would be the reason you would go down temperature ratings/higher numbers in the NGK code?
36Cycles wrote:Oil Quantity sorted, now I'm getting my head around what is the best Spark Plug to use!
If you were going to ride that Cota 123 on the road, you would want to be using a B9ES to reduce the chance of melting a hole in the piston. If you were riding trials or gentle trail riding on it, a B7ES would be suitable.
36Cycles
Post by 36Cycles »
Cheers, thanks for the simple explanation.
Higher Number=Colder Spark Plug type is good for riding on the road or more constant use/longer durations which requires better resistance to temperature. Running long durations on lower value numbers/hot plugs would cause excessive heat.
Not intending to ride on road, most likely to putt around in paddocks or still toying with the idea of joining a trials club and having ago, at nearly 40 I'd be most probably the oldest learner with the least experience.
So I think I'll change plugs to B7ES or B8ES
Thanks for all the help!
36Cycles
Post by 36Cycles »
Noticed that my bike doesn't have chain tubes or a tensioner,would like to fit tensioner anyone had experience with a good type or best location for fitment.
29MarkT
Bike: Montesa 200 Cota
Post by 29MarkT »
Hi, as regards the chain tensioner, I would advise fitting the original tubes and bracket, which are available from In motion, and prevent the chain jumping the gearbox sprocket and smashing the casing which is a common problem, some people have fitted a universal tensioner and used the long bolt hole on the bottom of the casing. I have fitted the original tubes, they keep the chain in good condition also.
The part numbers if you wish to search the net are as follows,
5120.369 - Bracket
5120.30601 - Tubes
Hope this helps,
Mark Trueman
England :montesa
http://www.facebook.com/groups/hardtofi ... ooledmono/" onclick="window.open(this.href);return false;
