I'm at the stage where I am putting the bearings onto the crank and putting the casings back together on my M158 Sherpa 250.
No dramas with the other bearings and gears etc....
This photo is well before I installed the bearings and gear sets. But these posts are much more fun with Pictures right!
But: 2 Questions for the Bultaco Brains Trust.
I have seen that some folks like to put the bearings onto the crank then then into the casings and others have put the bearings into the casings then warmed the bearings with a heat gun and put the crank in last.
Advice has been to install bearings onto the crank first then into the hot casings and I think this is the way I will go. Open to suggestions tho.
And I saw on Youtube a guy using a locktite product on the crank to hold the bearings on? Thoughts.
Do I need to put any gap between the bearing and the crank face? Or will it set itself?
AND:
It had no gasket between the casings, but the rebuild kit came with one and the destruction manual has a gasket.
I'm keen to use a gasket. Seems obvious but this bike has had some VERY dodgey work don't on it in the past.
With a gasket installed do I still use the oil seal retainers to set the spacing on the crank and just work from there?
And here's my beautifully rebored and bead blasted head and barrel. Just for Bultaco in bits porn. Its on its' final oversize.
Always interesting to get these clues into an old bike's past. Someone did lots of work on this, it obviously belonged to someone who was pretty serious about it's use.
Ian.
