TY250B Clutch inner basket
tjay7
Post by tjay7 »
Hi All,
when pulling apart my clutch the inner basket pressure bolt holes had some damage. When I went to reassemble one cracked completely.
Does anyone have another basked they would be willing to part with?
I have looked all over ebay etc and cant second hand or after market items.
tjay7
Re: TY250B Clutch inner basket
Post by tjay7 »
Photo attached
TY250B Inner Basket
TY250B Inner Basket
Inner Basket.jpg (205.83 KiB) Viewed 15392 times
tat ty
Post by tat ty »
Quite likely to still function. Heavy duty plates and light springs.
Worth trying.
Alastair
Yes Alastair is on track. Not even sure you need heavy springs. I have one that works fine with new plates and three standard springs. If you need to, those pegs can be heli-coiled if the thread is damaged, to get three good ones 120 degrees apart
Another other option is to have it (weld) repaired. I know of a TY250 clutch hub that was broken like that and successfully weld repaired by a friend of mine only a month or so ago
tjay7
Post by tjay7 »
Thanks guys,
I have put it back together and getting some friction. I will have to do some minor adjustments tomorrow but I think I will be fine with the existing one.
Looking forward to taking it for a ride!
Toby
