In an effort to avoid paying the ridiculous money Beta want for their LRK I have come up with a solution that I will hopefully have completed in the next week or so. I have gone with a TTR110 tank/seat combo as I could buy them for <$100AUD and the opening on the underside of the tank is the widest from what I could find in the size I wanted.
The seat tabs will mount at the rear of the sub frame with a little bending and the tank lines up beautifully at the front so that all I will need is an angled bracket mounted to the existing tabs for the front plastics. I will build a bracket for the underside of the seat to provide centre support and there are mounts on the rear of the tank that I will use to firmly affix it to the seat. It should be a very simply matter to mount/remove. The front of the tank will be opened up slightly with the use of a heat gun to allow it to sit lower. I'll need a length of fuel hose and a T piece to connect the secondary tank, but total cost should remain ~$100 + an hour or so of tinkering.
Unfortunately, my housemate of 5 years just moved out, so I will need to buy some tools that are needed before I can get stuck in.
Thoughts, critiques and general comments are appreciated!
Jimbo
