This site has some spares.
http://www.equipementmotard.com/index.p ... der&page=1
2004 ? fantic mono, twin disk trials bike
- whitehillbilly
- Club: SQTA
- Bike: Greeves
Re: 2004 ? fantic mono, twin disk trials bike
Thanks Rod.
Got the rear brake system sorted.
Bleed nipple was full of rust.
Pads look quite new.
Clutch and front brakes next.
- whitehillbilly
- Club: SQTA
- Bike: Greeves
Don't know if anyone can help, but I am after a good s/h hydraulic clutch an brake lever assembly.
Don't know if a Beta or GasGas one will fit.
Previous owner can't find where he put them, after removing them, as they were seized.
The brake calipers are AJP ones.
I will try and measure the thread sizes, the threads do look fine,, which surprises me as they are alloy.14 mm maybe.
The clutch pipe is about 4mm with the end scewing into the master cylinder, like wise the brake, not with a banjo, as I have seen on other master cylinders.
I will take some pics today of the ends and try and measure the thread size.
Will be at SQTA Sunday.
Another question,
Is the rim tape and valve stem one piece on a tubeless wheel. What measurement do I have to know, as the frantic rim is a stepped rim ?
Whitehillbilly
Another question,
Whitehillbilly
- whitehillbilly
- Club: SQTA
- Bike: Greeves
They both are M12 1.0 I think.
- whitehillbilly
- Club: SQTA
- Bike: Greeves
clutch and brake pics.
thanks
thanks
- clutch cable - Copy.jpg (46.97 KiB) Viewed 9490 times
- clutch thread - Copy.jpg (30.23 KiB) Viewed 9490 times
- brake cable - Copy.jpg (45.35 KiB) Viewed 9490 times
- front brake thread - Copy.jpg (27.2 KiB) Viewed 9490 times
- whitehillbilly
- Club: SQTA
- Bike: Greeves
1 step forward, 2 back at the moment.
Broke this, rear brake.
A common thing ????
A common thing ????
- rear brake - Copy.jpg (23.01 KiB) Viewed 9852 times
- whitehillbilly
- Club: SQTA
- Bike: Greeves
Stepped rear wheel.
standard tubeless rim tape ????
- rear rim 1 - Copy.jpg (23.87 KiB) Viewed 9852 times
- Rear rim - Copy.jpg (25.9 KiB) Viewed 9852 times
- Betaman
- Club: AJS Mcc
- Bike: BETA! wtf ;0)
The rear brake reservoir looks similar to a lot of pre 2010 rear brake setups.
Your rear rim looks like a Morad. It should have id marks stamped on the side. Fitting a rim
tape shouldn't be a biggie
Your biggest problem is finding the missing brake and clutch calipers. You could try this mob in the uk...
https://www.trialsbikebreakersuk.com/
My Videos - My Club
My Videos - My Club
Or Richard Allen
http://www.allensusedtrialsspares.co.uk/
From memory the same AJP calipers / master cylinders were same as used on many bikes around 94/95 - eg Gas Gas JT25, Shercos etc. Morad rim used on many bikes of that era - just need the sealing band or run a tube.
- whitehillbilly
- Club: SQTA
- Bike: Greeves
Thanks gents.
At least the pound dropping is in our favour.
Any one have anything closer to home ?
Whitehillbilly
Whitehillbilly
