New from Japan
ito
Bike: Beta Techno 1994
New from Japan
Post by ito »
Hi guys,
I am from Japan.
I have been thinking to get Honda TLR200 for long time,
but I got Beta Techno at last and received her yesterday.
I have to check some part before riding as she is second hand trials.
She is my first trials bike and could be too powerful for me.
Re: New from Japan
Welcome ito
Late model Beta Techno (after 1996 model) have a lovely mild motor and are good to learn trials on
Best of luck
ito
Re: New from Japan
Post by ito »
My Beta Techno is 1994.
Condition; Hydraulic clutch does not work
AJP master cylinder kit will be needed.
Or a complete master cylinder will be needed.
I am thinking I should upgrade master cylinder to REV3/EVO.
Master cylinder kit is not compatible. Parts inside differ.
The master cylinder for Techno is a little bigger than master cylinder for REV3/EVO.
2IC
2IC
Bike: Beta EVO
Re: New from Japan
Post by PA »
You may find this a solution to your clutch problems.
http://www.trialsport.com.au/beta/Manua ... ch_Fix.pdf
ito
Hydraulic clutch hose
Post by ito »
Thank you for solution information.
When looked at hose carefully,I found fluid leaking at middle of hose.
Beta genuine parts are not cheap.
So I will find aftermarket hydraulic hose.
Disc brake and hydraulic clutch hose use DOT4 as both are fluid circulation.
Which pressure is not high and worked by human hand and foot depression.
Cheaper hose has no transparent cover. I will get it at homedepo.
PA wrote:You may find this a solution to your clutch problems.
Re: New from Japan
Your bike looks to be in good condition for its age. I hope you like the motor. I found that the standard '94 Techno has a strong throttle response
ito
AJP clutch
Post by ito »
I removed clutch hose from engine but could not remove it from master cylinder which stuck as shown attached.
I splayed lube onto stuck part and am waiting for a while till tomorrow.
ito
AJP clutch
Post by ito »
That hose end was too tight to loosen this morning.
I wonder if hose end thread is clockwise or counterclockwise.
Or pre-owner glued with locktight? If so,I have to melt adhesive with heat gun.
Now I have removed hose from master cylinder afternoon.
Next step,I will get a hose for AJP clutch master cylinder.
Several hours later,I placed an order with HEL in UK.
TRIALTECH
Dealer
Dealer
Bike: Beta Scorpa Sherco
Re: New from Japan
Post by TRIALTECH »
The local Beta importer in VIC has a lot of parts in stock for the older Betas. Some really obscure stuff also. ..
http://www.betamotor.com.au
Denis
TRIALTECHMOTO
New and Used bikes
Spares and Accessories
[email protected]
http://www.ttmoto.com.au
0491.075.653
ito
Re: New from Japan
Post by ito »
Thank you for good information.
It is easy to find OEM parts for EVO and REV-3 as these are current catalog items.
But Techno is about twenty years old and so it is hard to find parts in Japan.
To maintain such old Motorcycle,some skills and experience will needed.
Techno is good enough to learn trials. She has still good capability.
