Hi, Pretty sure they are no longer available. You could try http://www.tytrials.co.uk/ I just read last night there is a company over here in States that is coating old Pistons to the spec of the cylinder.
We can crate and freight bikes Australia wide for very reasonable rates. Ring or email with your location for freight quote. The Hell Team Trials Store
02.8424.6400
0418.415.129 [email protected] http://www.thehellteam.com
Do you have any dimensions of the piston, it may be possible to substiute something else. Need to know things like diameter, overall length, pin centre to top outside edge, pin diameter and ring peg locations. I had a quick search and it seems that the old 360cc Yamaha piston come close at 80mm. There is an 80mm ATV piston I have been fitting to the early Yams but it requires a 3mm spacer fitting under the barrel as it is 3mm taller from the pin. Skirt is longer but that can easily be shortened.
