I am replacing broken block with new one.
I took a picture of old and new block as shown on attached.
Pre-owner seemed to give up replace wasted parts.
New from Japan
ito
- Bike: Beta Techno 1994
Chain slide block
- DSCN0542.JPG (461.32 KiB) Viewed 28605 times
ito
chain slide block
Front sprocket has to be removed when replacing chain slide block.
I tried to remove sprocket but could not.
Sprocket stuck on spline stiff. I am going to find good way to remove sprocket.
Then,I have decided to buy a 3jaws bearing puller to remove sprocket.
- DSCN0543.JPG (454.21 KiB) Viewed 28537 times
ito
Chain slide block and sprocket removal
I could remove sprocket with bearing puller. So I installed chain slide block.
- DSCN0651.JPG (329.81 KiB) Viewed 27625 times
- DSCN0642.JPG (174.02 KiB) Viewed 27625 times
- 2IC
- Bike: Beta EVO
Re: New from Japan
Good job. Better than pulling the swing arm out to do it.
ito
kickstart lever
As I replaced leaking fuel cock with new one,I tried to kick start again.
Unfortunately loose arm hit the frame and frame was damaged as shown attached photo.
I know best way buying REV3's kickstart lever.
And I am thinking another way to fix.
- DSCN9467.JPG (475.28 KiB) Viewed 26417 times
ito
kickstart lever bolt
Loose kickstart lever hit frame,so I put longer bolt with nut as shown attached. I hope it will work not to hit frame.
- DSCN9471.JPG (250.63 KiB) Viewed 25626 times
ito
Cooling fan does not work
I have got another problem in cooling system.
I started engine and several minutes later,
boiling noise came from radiator. But coolant fan did not work.
I thought thermostat wrong.
I removed wire harness from thermostat and I connect it to car battery.
The coolant fan work properly. It turned out to be wrong in thermostat.
BTW,
I am confusing which terminal is negative terminal and positive terminal?
Dose anyone know it?
BTW,
- DSCN9560x.jpg (348.41 KiB) Viewed 22856 times
JAKROO
- Club: Pacific Park
- Bike: nothing at the momen
Re: New from Japan
If the fan changes direction when you change the polarity/tweak positive-negative, then what you can do is set it so the air is pulled from the front of the bike towards the rear (that is from forks to engine)
Good work on the continuing rebuild/restoration of the bike to it's former glory!
- 2IC
- Bike: Beta EVO
Re: New from Japan
You can bypass the thermostat by joining the two terminals. This would make the fan run all the time which you may not want when it's cold.
- whitehillbilly
- Club: SQTA
- Bike: Greeves
Re: New from Japan
I used a tissue in front of the Radiator.
Sticks, its turning the correct way.
Mine is on all the time on my old Fantic Section.
