New from Japan
ito
Bike: Beta Techno 1994
Cooling fan
Post by ito »
PA wrote:You can bypass the thermostat by joining the two terminals. This would make the fan run all the time which you may not want when it's cold.
I saw Someone's Techno on Youtube bypassed fan. The fan runs all the time when ride.
Thanks everyone.
ito
Replacing with a new thermostat
Post by ito »
I could not find how to drain coolant fluid on service manual.
So, I removed fluid with injector. Some fluid remained.
I had set up a resin sheet and a bottle as shown attached photo.
I tried to replaced with thermostat not to leak fluid.
I made it. There was not fluid leaking.
By the way,
I have got junk HONDA TL125 JD06 last week,she is 125cc version of TLR200 twinshocks.
And she is registerable for on road ride. As my TECHNO is not allowed because no registration document.
TL125 is installed H-D sportster tank on attached photo. She does not look trials at all.
Techno thermostat replaced.jpg (452.51 KiB) Viewed 16792 times
2IC
2IC
Bike: Beta EVO
Re: New from Japan
Post by PA »
This is the coolant drain plug.
coolant drain plug.jpg (354.66 KiB) Viewed 16692 times
ito
Thermostat
Post by ito »
Thanks, PA.
I could not find coolant drain plug on parts list.
I will be able to drain as instructed next time.
The Hell Team
Dealer
Dealer
Re: New from Japan
Post by The Hell Team »
Just make sure you remove the top filler cap on the radiator as well when you remove drain plug.
Also you can wire up the Thermo switch either way as it is just a tool to complete or disconnect the circuit. It does not have to be polarity dependant. The fan does, but the thermo switch doesn't.
The Hell Team Trials Store
02.8424.6400
0418.415.129
[email protected]
http://www.thehellteam.com
Jordy
Club: none
Bike: none
Re: New from Japan
Post by Jordy »
That's what I thought. Thanks for the clarification!
There much fun to participate in ausopen club. Some events are not friendly still. That's why there a way to book there. It's better to read some info first.
