Parts commonality for TLR250r-Import 1986
Re: Parts commonality for TLR250r-Import 1986
Standard .will get back to you
Nil balance
- Club: none
- Bike: tlr250r
Thanks everyone, if anything pops into your mind, put on hear. Check 2 to 3 times a week.
Nil balance( a few ales tonight, nothing what soever.Sitting down)
eagle
- Club: oakleigh
- Bike: honda tlr 250
I thought the TLR 250 was a different bore to the TLR 250 R ?
- Club: VJMC
- Bike: TL125 TY175 GG280
Oooh-err Eagle, I'd better check the bore. I didn't know there were TLR250 models with 2 different bores, -that's a trap eh?
Thanks for the heads-up. I'm trying to get a piston (that is not insanely expensive) for my mate Jacko, who has done a great job bringing an incomplete box of bits back to life as a very presentable TLR250 (It's the earlier, first red white and blue TLR250). Only hitch is that he hasn't been able to find a piston for it, -it's presently running some 'other' piston, but the comp ratio is way too high, even though he's attacked the piston with a grinder -he ain't game to grind any more off it!
Bore: TLR250 ? TLR250 R ? Anyone know?
Rs250 tlr250 all 70mm did not change
- Club: VJMC
Now I'm REALLY confused!!!
What's this "RS250"?
I thought we were talking TLRs ?
Jacko needs piston for 70mm bore (which I assume is ALL TLRs including the TLR250R that Tony MAY have for sale.
-Jools
-Jools
eagle
- Club: oakleigh
Just did some searching TLR 250 is 70 x 64.9 TLR 250 R is 72 x 60 244cc
Gary Mc
- TA Supporter
- Club: OMCC
- Bike: Honda
I believe the TLR250R is unique, not the same design as TLR250F, Rtl250 or XR250 it appears to be made and sold mainly to the Japanese market.
Note where the kick start shaft is up high and the cam chain is on the RH side
- Honda tlr250r LH side.jpg (43.07 KiB) Viewed 14501 times
- Honda tlr250r RH side.jpg (42.59 KiB) Viewed 14501 times
Gary Mc
- TA Supporter
- Club: OMCC
- Bike: Honda
Hi Jools, not to hijack the thread but has your mate tried an extra base gasket or a spacer between the crankcase and the cylinder?
- Club: VJMC
No hijack mate, good to get your input.
No he hasn't tried a compression plate (yet?) he's hoping for a piston.
I might be overthinking it, but it would need quite a thick plate to reduce compression to what he needs, (guessing at this stage perhaps 1.5 to 2 'atmospheres' lower) and I wonder how that might affect the camchain and camchain tensioner setup. Obviously not such a problem with a pushrod motor (apart from pushrod angles), but OHC may be different. Looks like compression ratio needs to be 8.5:1 max, at the mo' It feels like it's at least 10:1 kicking it over.
(The last time I went through all this was on a '59 BSA Super Rocket!!!)
