Gas gas txt250 07 hard start
Glen N
Bike: TXT250 & Monty 247
Postby Glen N » Mon Jan 07, 2019 6:25 pm
Hey all,
I just bought an 07 txt250. She’s a bit hard to start and just wanted to get some general opinions on whether this is standard before I start pulling apart.
Also wanted to check the idle and mixture screw settings.
It’s got a dellorto phbl26bs carb, does have good spark even though I notice the plug was quite black when I checked it.
What’s the general consensus, pull apart the carb and check everything or bin the carb and get an oko or something similar.
The Hell Team
Dealer
Dealer
Re: Gas gas txt250 07 hard start
Postby The Hell Team » Tue Jan 08, 2019 8:03 am
Dellorto PHBL 26 stock settings on 07 PRO:
MAIN: 118
PILOT: 38 (36 OK too)
NEEDLE: D36 (3rd clip down from top)
FUEL SCREW: 3.5 out
FLOATS: level to gasket surface.
Plug - NGK BPR5ES or BKR5ES gapped at 0.6mm
95 Octane fuel
The Hell Team Trials Store
02.8424.6400
0418.415.129
whoever@thehellteam.com
http://www.thehellteam.com
pop
Bike: klx
Postby pop » Tue Jan 08, 2019 8:29 am
Zero throttle?
TRIALTECH
Dealer
Dealer
Bike: Beta Scorpa Sherco
Postby TRIALTECH » Tue Jan 08, 2019 11:04 am
confirm the kick-start lever installation position.
https://ttmoto.com.au/downloads/
TRIALTECHMOTO
New and Used bikes
Spares and Accessories
sales@trialtech.com.au
http://www.ttmoto.com.au
0491.075.653
Kurt
Bike: Montesa, SWM, Ossa
Club: TMTC
Postby Kurt » Tue Jan 08, 2019 2:17 pm
Before changing anything, ensure you have the right technique to start it.
Gassers revolve the engine very few times per a kick start in comparison to most motorcycles.
End result is you need to deliver a very sharp jab of a kick to impart the energy to start the bike.
I have found you need to stand quite far forward of the foot pegs so you can get the leverage to deliver the hammer blow required.
Vertically challenged persons may want to stand on a brick or something to raise themselves up a bit.
From memory no throttle is required, many people automatically apply throttle as they go through the motion of kicking.
Disclaimer: Ensure you have the kickstart gear properly engaged before delivering the kick start proper, as the bike uses a quarter gear that is very easy to break.
Glen N
Postby Glen N » Tue Jan 08, 2019 8:04 pm
Thanks for the replies, found the following;
Pilot was a 35
Needle was on 2nd clip
Kill switch couldn’t decide whether it wanted to be open circuit or closed circuit
Guess The hell team are getting a call tomorrow!!
Return to “Technical help”
Users browsing this forum: No registered users and 11 guests
