Hi All,
I recently purchased a TY250 b as a project and have only just started playing around with it. I cant seem to get a spark and have done a few things to troubleshoot but still no luck. Carb seems clean however I think ill have to pull it apart and clean the jets.
First, tested for spark with plug earthing on the head - No sign
Second, swapped for a new spark plug - still no luck.
third, disconnected the kill switch - still noting
What is the next step, should I be pulling the flywheel cover off and check the points?
ty250 no spark
Re: ty250 no spark
hard to say without more info about the bike, but the ignition points are a common reason for lack of spark.
You should be able to have a look at them opening and closing through the hole in the flywheel
Re: ty250 no spark
After having checked that the point open AND close, you can do the sand paper test: when the point are close slightly pry them open with a screw driver through a hole in the flywheel and lightly sand them with an extra fine piece of sandpaper ( I usually use a nail file ) check the sandpaper for trace of oil. Do not over sand. If you have a spark after that, it's time for new point.
Users browsing this forum: No registered users and 30 guests
