Fantic Water pump seal
Freddypatto
Club: TCV
Bike: Fantic
Post by Freddypatto »
I currently have a 94 Fantic Kroo, I have had to replace the water pump seal and have had no luck in finding a seal. It looks to have a shaft size around 7.5mm and is about 17mm x 17mm. The seal has no numbers on it. Bit stuck, does anybody know where I might find one of these little seals.
Gomey
Club: SQTA/LRMTC
Bike: Honda RTL
Re: Fantic Water pump seal
Post by Gomey »
I have used this company with good success for hard to find seals. You can put in all dimensions and what materials you need it to be made out of.
https://www.123bearing.eu/
