David Lahey wrote:Bully fanatic wrote:Greg have to ask. Wouldn`t the 9 tooth countershaft sprocket wear the chain out very fast? The smallest I can go on a real Trials bike :Bultaco: is an 11 tooth. I can remember reading that folk used to warn against using a 10 tooth on the front as it made everything wear really quickly.
Graham, maybe power is needed to wear out the front sprocket and of the two, only the :Bultaco: has that?
Shouldn't we be more worried about torque David?
Fair question Graham, I think you might be surprised how many bikes run a 9T since
went out of production?
are limited with them having the clutch pushrod through the Centre of the counter sprocket shaft.
Now that I think about it, depends on the choice of chain, how you maintain/lubricate it and how long you run the chain. An old story always make me laugh goes something like this:
When you run out of adjustment on your chain and you have to remove a link, the chain wears out really fast after that!
TLR 250s came standard with 9T and I think TLR 200s as well. Pretty sure RTLs came with 9T along with 4RTs up until and including present models.
It is not just a
thing, I choose to run a 9T on the the front of TLR 200 to get the gearing that I want, if I go to a 10T like on my
BLOODY
, I would need to run 55T on the back and that is getting big enough to affect the pull of the chain.
XR 200 which is what TLRs are based run 13T and that makes sense in terms of wear most likely because they are expected to do more kilometers?
The difference between the TLR models is in the primary drive with the 250 being a lower ratio.
Apparently the 250 has a different 6th gear as the bigger cylinder gets in the way, I have never had either apart.
The wheels and hubs are different, the clutch actuation arm is shorter on a TLR 200 and anyone can feel free to add to the list........
- 1593168911935.jpg (92.31 KiB) Viewed 2227 times
- 1593168934524.jpg (100.46 KiB) Viewed 2227 times
- 1593168980591.jpg (55.73 KiB) Viewed 2227 times
Has anyone got similar brochures for TLR 200? There is an old story that
Australia bought 1 bike in but never pursued it until the 250 came out, I have always been curious about how many
TLR 250s were sold in Australia?
Might it be 80?
