Graham, I wasn't serious about the gear-drive kit for your Sherpa's. (The cost is all-but prohibitive anyway.) Just a bit of a laugh to remind you of your pursang's whine. I also recall reading that chains were claimed to be more efficient, but I have no idea if it's true. Everybody eventually went to gear-drive. In the case of the Mk10 Pursang and that kit there are extra losses with an extra gear in the primary drive with its bearing etc. The claim of 2Hp increase in TSS250 engine I suspect is due to the much lighter rotating mass of the new clutch etc
The clutch cover spacer though might have saved you from having to shave the nuts.
Dave, that is a nice looking Lobito conversion. I've seen a couple done and I think we still have one such modified Lobito frame in the shed at Calliope.
Is that a Honda front end on it? (TL/SL125?)
JC1 wrote:Dave, that is a nice looking Lobito conversion. I've seen a couple done and I think we still have one such modified Lobito frame in the shed at Calliope.
No :Honda: bits there, it's got :yamaha TY175 forks and triples. The footpegs are back in the normal trials position and the brake pedal is on the right with a cable going over the carby and back to the brake arm. 52" wheelbase.
What front end was used on the one at Calliope?
Bultaco, Bultaco, Bultaco
Here are a couple of video clips from last Sunday of Steve and I in the railway cutting section after the trial. Where we rode is on the white line, previously known as Clubman.
The bikes both sound like they have engines full of loose nails. I'm thinking this is partly the way my phone compresses the sound track and partly because both bikes have quiet exhausts.
Steve's Lobito 175 has a TY Offroad TY175 one-piece muffler and my Sherpa T has a standard main muffler and a Spanish aftermarket triangle muffler.
Youtube links:
https://www.youtube.com/watch?v=QiLQQcOJT3o
https://www.youtube.com/watch?v=qLwSgLWJgtk
Yes I noticed the cross-over brake cable.
Is it still a 175?
The one in the shed at Calliope was only a frame Dave. No front end
Is it still a 175?
Yes still a 175. He only found out after rebuilding the engine that they can be converted to 250.
Kawasaki reassembly
Warning - attempt at self-deprecation humour follows:
While I had the :kawasaki KT apart I decided to replace three of the four steel front engine mount spacers with aluminium.
So by the look of this, three of these babies reduces the bike mass by even more than using one of those Chippy brand :kawasaki aluminium exhaust flanges :shock:
People who have taken a KT engine out will probably know why I only replaced three of the four steel spacers
Back on the whine tour again
A few pages back Greg Harding wanted me to post up a photo of my :kawasaki KT whine generator but I wasn't at that stage with the reassembly of my motor, but am finally there today.
Greg did later post up a :kawasaki whine drive photo and the challenge is for anyone to notice an important difference to mine pictured here.
Phil 850
Post by Phil 850 »
Not whine related, but your throw out bearing is flush ?
Phil 850 wrote:Not whine related, but your throw out bearing is flush ?
I wondered about that too but it's not the answer to the challenge. I suspect Greg's throwout bearing is a bit wider to get the adjustment right for his KX250 clutch cover
TerrY
Bike: Beta 200
Post by TerrY »
David,
Might it be the number of springs in the clutch?
TerrY
