JC1 wrote:You may like to consider Kaw F11 triples to get a little more trail on the modified KT frame Dave. If I recall correctly they have about 10mm less offset than the KT's which might just be about right for you, and they are both alloy. Don't know about the distance between the tubes but the steering stem should be about the right length for the KT frame. I considered such a swap for my KT when I noticed it occasionally doing that tucking under, as you describe. But I decided I can live with that as I otherwise like the KT's steering, apart from the bike being a bit too front-heavy which is why I'd like to rearset pegs too.
That's a tempting idea John. I was thinking of riding it for a while to get a better idea of what I might want to do next, and lengthening the swingarm is something that is already ruminating in my head, so if I went that way I could make allowance for the wheelbase shortening effect of the F11 triples at the same time. It's borderline short wheelbase already so I want lots of riding time on it to see if that is a problem or not.
F11 triples give 10mm more trail, depending on if the difference in trail is from having less angular offset or from having less forward offset, the fork tubes may hit the fuel tank on full lock. It would be good to know how much angular offset the F11 triples have.
motor definitely fits in the
frame but the exhaust port looks a little close to the downtube and there is not much room for the exhaust below the tank ? That must be as labeled a TS 250 A motor with the exhaust port on the other side.....
and yes I had the thing fitted the wrong way around
