After Kurt asked about the inlet rubber for my 210cc TY175 I got some different ones out for a look and was quite surprised with a few things.
The photos show four different inlet rubbers that would fit a TY175, some with a bit of modification.
The standard TY175 rubber is sitting on a TY175 reed cage. The other three reed cages are the bigger size that comes in TY250, DT175 and lots of other
s.
The issue that is perplexing about TY175 inlet rubbers is that the hole on the rubber doesn't line up fully with the hole in the reed cage. This is a source of drag that on a racing engine would be extremely important but on a trials engine not that important, but maybe something that could be improved upon for people who want to get the best out of their bike.
I'll stick one photo here and identify the inlet rubbers:
- 20220116_093515.jpg (1.13 MiB) Viewed 965 times
Starting on the left end
TY250 has 434 moulded into it
DT175A no number moulded into it
something with a boost bottle. Could be late model DT175, RD350/400. No number moulded into it.
TY175 has 525 moulded into it
Note that the one with the boost bottle connection is the only one that has the carby positioned centrally.
Some one has trimmed the fairing off the one with the boost bottle connection, presumably so it would fit onto a TY175 reed cage.
The standard TY175 cylinder is too narrow to fit the wider TY250/DT175 reed cage but it is only a few mm too narrow and some people have widened it a bit to fit the bigger reed cage. All the carby connections are the same size ie they fit TY175 or TY250 or 26mm OKO carbys.
Here are the rest of the photos. I've tried to show the misaligned flow path with the TY175 rubber.
