Engine Oil
Beech
Post by Beech »
Just checked mine, it's 5/30, my local Repco has it on the shelf so don't know why the web site doesn't have it, have you tried Repco?
Club: TCC
Bike: 06 Sherco 250
Post by Neo »
Hi Beech,
Thanks for checking. I will pop into Repco and buy it there.
5w30 is on the US Pennzoil site. So I don’t know what their game is.
Is this a Fully Synthetic Oil?
Best of balance.
Beech
Post by Beech »
Semi Synthetic, give it a go.
Sherco H
Post by Sherco H »
SE Lucas,
If your getting clutch slip, either the plates are worn,or the master cylinder is not set properly, and no type of oil will fix that.
There must be some play between the lever and the master cylinder, so as the hydraulics are not applying pressure ,and causing clutch to partially dis-engage ,or slip. If plates are worn they can be measured to see if they are below recommended thickness and may need replacing.
ShercoH
I`m a pupil of experience !!
S.E.Lucas
Bike: 00 290, 4RT
Post by S.E.Lucas »
Sherco H wrote:SE Lucas,
What if the clutch fluid was bad or there wasn't enough, what would that do?
Club: TCC
Bike: 06 Sherco 250
Post by Neo »
S.E.Lucas wrote:What if the clutch fluid was bad or there wasn't enough, what would that do?
Simply, you'd get clutch drag (not slip). Is Clutch drag what you're describing?
I'm testing a new oil for this (Pennziol has been discontinued by Repco and no one else seems to stock it).
Good to see you back here Lucus.....what have you been upto?:wink:
Best of balance.
S.E.Lucas
Bike: 00 290, 4RT
Post by S.E.Lucas »
Drag is when you pull it in but it still keeps moving a bit right? I get the one where I accelerate and it just revs. I'm pretty sure it's the plates but I was hoping there might be something else it could be.
I haven't got around to fixing it since I've been working full time in Botany. I either have no money or no time, I can't win :lol:
Club: TCC
Bike: 06 Sherco 250
Post by Neo »
Bugger....
I threw away a set of 290 clutch plates only the other day. They were used (but still in very good condition) but I thought that I never have a use for them. And you could have had them for nout..
I gotta stop having these garage clear-outs the wife insist on :roll:
If your sure the lever is adjusted with some slack. Then I'd say the plates are the most likely thing.
Have a chat to Don...I don't think they were that expensive....
Best of balance.
S.E.Lucas
Bike: 00 290, 4RT
Post by S.E.Lucas »
Neo wrote:Bugger....
Best of balance.
Damn, that's a shame. I think I'll go ahead and buy some this week.
I'll let you know when I get it fixed if you want to go for a ride?
Hopefully my body will be up to riding when I get it sorted.
Club: TCC
Bike: 06 Sherco 250
Post by Neo »
Hi Beech,
I found out that Repco has stopped supplying Pennzoil 5w30 but I found Castrol EDGE Sport 5w30 at SuperCheap Autos. And have been testing it out these past couple of months.
http://www.castrol.com/castrol/productd ... Id=7013361
It is also Fully Synthetic. And I must say that "it’s the best".:thumb:
I didn’t happen for a week or so, but I can now click my bike straight into first from stone cold and stay stationary. I guess the clutch plates took some time to fully soak in this oil.
It has also changed the feel of the clutch too. Less movement is required to go from dis-engaged to engaged. But it's quite smooth. That works well for me on my Sherco but I’m not sure how it will work for other bikes.
Many, many thanks for the tip.
Best of balance.
