Page 2 of 4
Re: New from Japan
Posted: Fri Aug 12, 2016 10:42 pm
by Tioli
Thanks for the tip Ito
I have just the rubber to make grip pads like yours
Prior to ride
Posted: Sat Aug 13, 2016 5:44 pm
by ito
Prior to ride,I am studying Techno.
As she is my first 2 stroke motorcycle.
I was wondering where I should fill cooling liquid.
Cap of EVO locates top of radiator.
But Techno has no cap at top of radiator.
I found the tank cap locates next to fuel tank cap.
Wow,I have to mix fuel and engine oil by myself.
I thought filling separately and mixed automatically.
Real competition motorcycle!
updated.
Received Hydraulic clutch hose from HEL in UK
Posted: Fri Aug 19, 2016 5:42 pm
by ito
I have received the hose from HEL in UK. What a surprise ! It took only 8 days!
Posted: Sun Aug 21, 2016 7:48 pm
by ito
I replaced damaged hose with new one from HEL.
I filled DOT4 but DOT4 did not flow and no air came out.
Spring could have wasted or rubbers for piston could have wasted.
Or cylinder housing could have wasted.
Nevertheless I will replace with complete Hydraulic master cylinder with lever.
Alternative hydraulic clutch
Posted: Mon Aug 22, 2016 7:08 am
by ito
If nesessary,I will buy latest clutch master cylinder for 2015 EVO.
Does it work at Techno ?
Clutch repair
Posted: Mon Aug 22, 2016 10:42 am
by ito
I decided to overhaul master cylinder.
When opened,rust came.
Umm..
Spring receipt cup stuck at entrance.
Re: New from Japan
Posted: Wed Aug 24, 2016 11:56 am
by ito
Finally I could get out piston which rust worst.
Worn side stand
Posted: Sun Aug 28, 2016 11:27 am
by ito
Side stand receiving part worn so that body could not stand alone.
I made a aluminum spacer in order to go side stand backward.
It is not bad. When worn again,I will replace it with steel plate.
Hydraulic clutch issue
Posted: Sun Sep 11, 2016 11:18 pm
by ito
I gave up replacing with new seal kit and HEL hose.
Finally I got Chinese master cylinder and hose as shown on picture.
I assembled them onto Beta and filled DOT4 fluid.
Then I found a piece of chain slide block lie down on bumper plate.
Every parts seemed to be worn. Chain tension block is as well.
Gas leaked at petrol cock
Posted: Thu Sep 15, 2016 5:47 pm
by ito
As I finished installation of new clutch system,I filled mixed gasoline to Beta.
But gasoline leaked at on position. I will replace with new petcock for Techno.
