Posted: Tue Jan 31, 2006 11:14 am
I just did the repacking of the Beta Rev 50 for the first time (a regular occurence on the KTMs!!!).
The silencer casing is riveted to inlet and outlet end caps. A baffle tube runs between the two. So I...
1. Drilled out the rivets carefully
2. Tapped the holes in the end caps 6mm
3. Made the holes in the casing slightly larger to help line up the end caps in the casing at re-assembly time.
4. Pulled out the old packing which was dripping with oil - errr yuch...
5. Wrapped my favourite Bradford Insulation Rockwool around the baffle tube. Held in place with paper masking tape.
6. Re-assembled with short 6mm stainless cap head screws.
Bingo...nice looking job, with serviceable silencer and better running bike.
