Good point George. I just checked JB Weld Industrial:- not recommended above 600F/320C. Its a long time since I used Devcon but I seem to recall it was only rated to about 100C. (It was used on a low temp application of oxidised magnesium cases (SWM) which have since successfully survived over 15yrs regular VMX racing). I've heard some say JB Weld is much better than Devcon, others say its much the same.
One problem with applying it after the liner is inserted is preventing it bonding to the liner. Otherwise I'd think it'd cause considerable problems if the liner ever had to be removed again.
Yeh Greg, the problems with the 242 kickstarter are well known. I was assuming it had broken/missing k'start gears but I don't know if you have any of the kickstarter mechanism/shaft/gears/lever. I'm lead to believe much of the cause of the problem of broken gears is that when not carefully assembled/aligned (even from the factory) the gears which are already narrow only partially engage/overlap and therefore break the teeth, but I'm sure Chippy would know more about that.
If that issue can be addressed with careful (re)alignment/assembly, & if you have the rest of the mechanism in working order, the gears are currently available from inmotiontrials in the UK:
https://www.inmotiontrials.com/product- ... s-montesa/My thinking was that if you combined that with fitting a compression release ALWAYS to be used while starting, it might be a whole lot less work compared to your current option when you consider what that will entail: raise tranfer ducts & inlet tract, fill/reshape inlet tract and boost port duct, bore cylinder to take liner, machine top & bottom of cylinder, fit liner, fabricate new engine mounts, modify connection to air-box/cleaner to suit, modify double down-tubes to suit side-port exhaust, build suitable exhaust system, switch rear wheel to RH drive & modify brake accordingly. That's a heck of a lot of work & if you have to pay for some of it to be done, does that make it uneconomical?
Come to think of it, compared to all that, perhaps your original option of adapting the 242 cylinder onto the 247 bottom end is worth considering again! Are there less problems to surmount there ???
Or another option with considerably less work might be to find a 348 Cota engine (as they have centre port exhaust) for an engine transplant ??? That might turn out more economical in the end. 348s were fairly common and stone reliable, and if you prefer 240cc to 306cc, it can easily be converted with a 248 Cota cylinder which are often on ebay.
Anyway, just tossing ideas forward Greg, not trying to convince you one way or the other. I'ts very interesting thinking thro the options & potential problems on projects like this. I've no doubt in your skills to make whatever option you decide on to work.
