Page 244 of 324
Re: Custard Tart
Posted: Thu Jul 16, 2020 5:19 pm
David, that is Dave and Emma Harris who always rode together and I can remember talking to them about their bikes, they lived in Tweed Heads/ Murwillumbah area. You may have found Whitehillbillies :suzuki ?
Yes Greg and I had the idea that they had a motorcycle shop. I also remember buying some new TY spoke sets from Emma a while after they stopped riding.
Posted: Thu Jul 16, 2020 7:43 pm
by SQUAT 405
Greg thanks youve got it 8),,,,, bahhhhhhh thats a classic ,,,,, :D
Posted: Sat Jul 18, 2020 5:19 pm
by JC1
David Lahey wrote:I haven't found a photo of any custard tarts yet but did stumble across this interesting looking :suzuki .
Photo taken at the 2008 Qld Titles
That RL looks quite nice in orange and black. Nice wrap-around bash plate too.
Brent, you mentioned (in another thread) about modifying RLs in NZ back in the day. My cousin's husband rode a lot of trials there. When I was last there in 2009 he showed me his modified RL which was like this one.
Frame modified.jpg (158.71 KiB) Viewed 2618 times
This is not his but he said it was common to mod them that way in NZ "like the Mk1 Beamishes" - just remove the backbone tube below the top rear engine mount then move the swingarm forward. I thought at the time that it only solves one of the RL's shortcomings (reducing the long wheelbase) but potentially exacerbates others. (And I still think that.) He seemed to think it worked pretty well.
Did you have any experience with RLs modified that way in NZ?
Posted: Sun Jul 19, 2020 8:03 pm
by brent j
Brent, you mentioned (in another thread) about modifying RLs in NZ back in the day. My cousin's husband, Alister Thompson from Taranaki region rode a lot of trials there. When I was last there in 2009 he showed me his modified RL which was like this one.
We never did that mod but I can see the sense in it although they needed a longer swingarm.
My mate wanted more ground clearance so I made new front and top engine mounts that lifted the motor 25mm. Can't remember how I changed the lower rear mounts and we removed the frame tubes under the motor and made a bashplate. He was a very good rider but had no mechanical aptitude and said he liked the top heavy feel.
Posted: Mon Jul 20, 2020 6:27 am
by brent j
My mate wanted more ground clearance so I made new front and top engine mounts that lifted the motor 25mm. Can't remember how I changed the lower rear mounts and we removed the frame tubes under the motor and made a bashplate. He was a very good rider but had no mechanical aptitude and said he liked the top heavy feel. The other addition was a fillet in between the gussets where the frame always broke. I 'm sure I did both sides after repairing the tube.
Posted: Mon Jul 20, 2020 6:47 am
TerrY wrote:Reading about CUSTARD TART, I recall another Custard Tart which was a TY I think and ridden often by MR. So there must have been more than 1 Custard Tart. I don't remember the Honda one ridden by JB.
Would some one with a better memory please explain???? Was there a batch of Custard Tart paint that fell off the back of a truck and circulated around the southern Qld trials community???
I await an explanation.
TerrY
Terry is this the custard tart you were thinking of?
Posted: Mon Jul 20, 2020 8:05 am
by Grassy
I was given the opportunity to swap bikes with Greg TL-climax yesterday at the end of the trial.. The brakes not only worked, they were perfect.
So please Greg, and all you other regular contributors to this epic thread, help a novice out and spill the beans on the secrets =D>
Jeremy
Posted: Mon Jul 20, 2020 11:47 am
Grassy wrote:I was given the opportunity to swap bikes with Greg TL-climax yesterday at the end of the trial.. The brakes not only worked, they were perfect.
Jeremy
I witnessed your surprise regarding the working brakes on Greg's TLahhhh yesterday. I don't know what's wrong with yours but the usual causes for weak drum brakes on trials bikes are:
Lining radius not matching drum radius.
Lining material choice not ideal.
Drum surface not flat.
Rarer causes include:
Shoes not centered.
Play in wheel bearings.
Contaminated linings.
Cable drag.
You may be surprised to know how many of the people you rode with on the weekend were riding bikes that had drum brakes prepared to maximise performance. The usual method for worn drums is to machine the drum surface flat again. Then the shoes are relined with thick brake material that is then machined down so that the radii of drum and lining match. The lining material chosen is important too and modern non-asbestos lining material is available with fabulous friction properties.
Posted: Mon Jul 20, 2020 7:16 pm
by TerrY
David,
Regarding "Custard Tart", I don't think that that bike was "Custard Tart". I think it may have been a TY and the yellow was all over the bike and it was not a very nice look. I hope some others can remember the bike I am thinking of.
TLAhhhhhh 200 with brakes
Posted: Mon Jul 20, 2020 9:36 pm
Jeremy
Shoes not centered.
Cable drag.
Thankyou Jeremy for the ride on your :honda: TLR 200, it is always good to compare bikes and yours is a very nice example! TL-climax :shock: :lol: :lol: :lol:
OK, so I will try and answer yours and David's questions. David, Jeremy's 200 has TLR 250 wheels fitted and the brakes were a bit lacking. The rear pedal had quite good feel so I don't think the shoes were not centered or mismatched in diameters and likewise the bearings did not feel loose riding the bike. There was no pulsing so I am pretty sure the drums were round and my most likely conclusion without pulling them apart is contaminated linings, some photos of the inside would help here Jeremy?
The front was pretty much the same in feel but the feel was slightly springy and I didn't have a close look at the cable (riding over rocks) but I suspect it was a 2.0 mm cable. Again if you could measure this Jeremy, 2.5 mm cable has less stretch in the inner and less compression of the outer giving a more direct feel and better feedback. Avoid buying a 2.0 mm front brake cable especially the ones designed to go over the headlight as they add an unnecessary extra bend robbing you of feedback. The front was more effective than the rear and likewise photos disassembled would help? My assumption is the same as the back, most likely contaminated but there could be a dusting of debris working like little marbles or maybe beans in this case inside the drums?
As for the
[marq=left]TLAhhhhhhhhhhhh[/marq]
Basically the brakes are off bikes designed to go faster and therefore have more effective brakes. A mate of mine is always wheeling and dealing in bike parts and we have done some weird and wonderful swaps, I always like going to his place to check out the latest scores and he is always keen to come to my place. Sometimes he will even detour to my place before going home just to show me what he has picked up and is always keen to swap for any of my bargaining chips. The negotiations are the best part as we both always want win win! Anyway he is a :honda: nut and most of the components except stainless steel spokes and TL 125 rear rim came from him in dribs and drabs. They are all :honda: parts and I am hoping some :honda: fans can help identify them for me?
As for brake shoes, I just use off the shelf EBC grooved shoes at about $30.00 a pair from our local :honda: dealer. As David said, there are all sorts of different lining materials available but when you can get effective brakes for $60.00 and a little effort, I have not felt the need.
Here are some more photos starting with the controversial log jam shot next to the Orara River :
This one has the TLR 200 front brake arm as I was waiting for the TLR 250/TLM 200 front arm to turn up that was fitted just before the weekend:
