Posted: Mon Feb 08, 2021 8:03 am
Nice work Dave
Our goal - promoting a MotoTrials Community
https://forum.trials.com.au/
JC1 wrote:Nice work Dave
David Lahey wrote:I've spray painted the colour coat on a fuel tank........
This is the blue paint I used
restoration ???
at bottom right? Or even better still, translate the text?Greg Harding wrote:Hi Everyone,David Lahey wrote:I've spray painted the colour coat on a fuel tank........
David, I am not familiar with this paint, is it the type with a hardener capsule inside that you rupture when you want to use it?
Can we have some more photos of your beautifulrestoration ???
On another note, does anyone know anything about thisat bottom right? Or even better still, translate the text?
Greg Harding wrote:Can we have some more photos of your beautifulrestoration ???
David Lahey wrote:Greg Harding wrote:Hi Everyone,
Here is a link to the modern magazine article I was referring to and some more photos of that KT330 in Japan
https://kawasakikt.tripod.com/KT330.html
KT250 motor has been apart for over a year so there was a bit of head scratching while I worked out how to get the gearbox back into the left engine casing.David Lahey wrote:ThisKT250 motor has been apart for over a year so there was a bit of head scratching while I worked out how to get the gearbox back into the left engine casing.
This motor was pulled apart initially just for a rebore and then I decided to replace the (original 1976) conrod while the cylinder was off, because I plan to never have to work on this motor internally again. The cylinder and crankshaft work was done pre-covid by George McKenzie but I'm only now getting to put it back together again.
This photo was taken this morning just before I put the left and right cases together. I put the rest of the bottom end together afterwards and now it is sitting waiting for some new, longer, cylinder studs to arrive so I can put the cylinder on.
Whinery David, what cylinder studs did you get?
Whine Maturity compartment?Greg Harding wrote:Hi Everyone,David Lahey wrote:ThisKT250 motor has been apart for over a year so there was a bit of head scratching while I worked out how to get the gearbox back into the left engine casing.
Nice photos ofWhinery David, what cylinder studs did you get?
Did you snap any photos of theWhine Maturity compartment?
KT250 Whine Production Department but didn't and the clutch cover is now on.
KT250 clutch cover off at the vapour blasters this afternoon and when I swap the covers over I'll take a photo for any interested Whine Connoisseurs.
KT engine covers for blasting so when this motor is complete it's going to be so bright I'll need sunnies to look at it. The cylinder and head and inner engine casings have been vapour blasted previously.
