Re: Bultaco Bultaco Bultaco
Posted: Fri Sep 23, 2022 1:56 pm
After going through some more :Bultaco: parts, I found another head with 3 holes. Here are some comparison photos:
Both heads appear the same except for the number 105 stamped in the underside of the second beadblasted head, maybe it means something? The centre hole looks to me like it was machined at the same time as the others with a similar recess even though they have different depths. They fit neatly on to a 325 cylinder with 83.4 mm bore.
Greg, both those heads are from Mk5 M87 and Mk6 M104 350 Pursangs which had 83.2mm bore and 60mm stroke for 326cc, same as early 326 Sherpa Ts and Alpinas. They have the narrow stud spacing (for the 4 long studs) of all the 125/175/250 Buls (prior to the Mk 11 250s) and the early 326 Alpinas and Sherpa Ts (M99 and M92).
On the Mk7 360 Pursang (M121) they went to 83.7 bore and 64mm stroke for 352cc and also moved the studs out wider as they did on Alpinas and Sherpas, but I'm not sure on which of those models they changed. I think it was the M116 Alpina.
On the Mk 8/9/10/11 etc Pursangs and similar era Fronteras they went to 85 bore for 363cc and moved the studs out further still.
So your heads will fit the MK5 & 6 Pursangs, and early 326 Sherpas and Alpinas (obviously with fins trimmed), but not the later ones.
Majesty and it took a lot of experimentation before I was happy with the fork action.
KT so decided to try the same setup on the Majesty forks. The KT has aftermarket TY250 aluminium damper rods and TY250 Magical springs. Compared to standard TY250 damper rods, the aftermarket damper rods have smaller damping holes and are a bit longer.
MAR motor on my bike workbench was getting in the way so I've done a video before storing it out of the way.
) hey Bullylover?
