Page 305 of 324
Re: which way up for multi rate fork springs
Posted: Sat Oct 01, 2022 10:07 am
David Lahey wrote:Does anyone have input for which way up progressive fork springs should be fitted and why?
David, isn't half of the length of springs considered unsprung weight? Therefore wouldn't you fit the heavier end of springs at the top? While I am asking questions: Were we talking about unsprung weight with regards to gold valves and damper rods instead of springs?
So many questions.....
Posted: Sat Oct 01, 2022 2:19 pm
Greg Harding wrote: Were we talking about unsprung weight with regards to gold valves and damper rods instead of springs?
I was hoping you had forgotten about the unsprung weight effect of the gold valves because when I went to weigh the damper rods I realised that the damper rod I modded to fit the gold valves to is a different design to the standard TY250 damper rod. I think the one that I modded is a :kawasaki KT250 damper rod and it has a steel head and a steel piston and even with all the extra holes carved in it and the top machined off, is heavier than a standard :yamaha TY250 damper rod with its aluminum head and aluminium piston.
I think I'll just weigh the Gold Valves and forget about the compensatory effects of the damper rod mods weight loss.
Posted: Sat Oct 01, 2022 2:22 pm
Bingo Greg :D
Unsprung weight effect of Gold Valves
Posted: Sat Oct 01, 2022 2:57 pm
Especially for Greg
I finally did something about a distraction
Posted: Mon Oct 03, 2022 7:33 pm
Yet another little thing to make riding a bike better.
Over the past two weeks I've been setting up the forks on a few twinshocks.
This afternoon thanks to the public holiday I've made a prototype guard to stop my boots getting hooked under the fibreglass seat base on this TY250.
It was fine with my Alpine Stars boots and a standard :yamaha exhaust mid-section. Then I went and got new Forma boots and the WES exhaust and ever since then, whenever I wore the Forma boots on this bike the top edge of the RH boot would repeatedly catch under the edge of the fibreglass seat base which was quite a distraction when trying to ride sections.
I first made a cardboard version to get the dimensions then made this one from 3mm HDPE. It's a lovely bike to ride apart from the boot catching thing so I'm looking forward to trying it out soon.
Posted: Mon Oct 03, 2022 10:17 pm
by Guy53
The '' nicer '' is a bike to ride the more you want to ride it. Good job David.
Honda Honda Honda
Posted: Tue Nov 08, 2022 8:39 pm
Just sharing my latest TL 250 acquisition:
:honda: :honda: :honda: :honda: :honda: :honda: :honda:
Posted: Tue Nov 08, 2022 8:55 pm
by Bully fanatic
So another Ocean Liner Anchor Greg. Very interesting. :roll: :roll: :roll:
Posted: Tue Nov 08, 2022 10:08 pm
Maybe without the :honda: motor, the rest may well weigh the same as a normal trials bike. I hope you do a weight comparison Greg.
It does look very "strong" though :shock:
TL 250 Bare frame weights
Posted: Sun Nov 13, 2022 3:15 pm
David Lahey wrote:Maybe without the :honda: motor, the rest may well weigh the same as a normal trials bike. I hope you do a weight comparison Greg.
Here you go David, Just under 11. 5 Kg or one :italjet: Piuma frame and 4.5 Kg of ballast.
Bully fanatic wrote:So another Ocean Liner Anchor Greg. Very interesting. :roll: :roll: :roll:
At first I thought you were joking Graham, :bultaco: Pot calling the :honda: kettle black kind of thing but then I looked at this:
It was then that I realised your theory does NOT hold water! :roll: :roll: :roll:
