Interchangeable parts for TY175
outforfun
Bike: 2002 Sherco 290
Post by outforfun »
Hello, I would like to ask the learned gentlemen and women a question that has popped up when trying to find parts for my TY.
Are other Yamaha 175 parts interchangeable? eg, AG175, DT175, IT175 any others?
I mean is an IT 175 fork tube interchangeable?
With or without a little mod here or there, do other bike parts fit. I remember someone modified a DT175? engine cover for example.
Thanks, Don.
Tee-Why
Re: Interchangeable parts for TY175
Post by Tee-Why »
"Are other Yamaha 175 parts interchangeable? eg, AG175, DT175, IT175 any others?"
Don, the AG is out, as they are based on the earlier series, however some bits off the DT175C/D and IT175D (first model), and also the YZ125B/C/D I think.
I did compare bits off a DT175C I have, there is a some commonality, but a lot of differences, eg clutch, flywheel, crank tapers, cases, but surprisingly the porting and piston are common, but barrel is bigger finned. Only bit worth swapping was the bigger 24mm carb that needs to be rejetted. Fork lower legs are different, similar springs, different internals slightly. All else was bigger and heavier. A future resto project!
Seen that others swap the RHS case cover to the YZ one when the oil pump is removed, with some adjustment.
Hope this helps.
outforfun
Post by outforfun »
Hi everybody.
I have just purchased another 2 TY's as parts bikes. I'm looking to make one go again and need a new airbox to carby inlet pipe. They are apparently NLA. Is there any other bikes etc, that I can get the pipe from and be on my way to going again?
Cheers, Don.
Gomey
Club: SQTA/LRMTC
Bike: Honda RTL
Post by Gomey »
I have 2 new old stock fork tubes for a ty175c if anyone is interested?
Twinshock200
Bike: Classics & Twinshock
Post by Twinshock200 »
Gomey, yes please, 0402736045
Pre 65 Classic bikes
Twinshock200
Hi Outforfun or anyone else
I know someone who is looking for some TY175 parts, he is unable to get on this forum so could you call him on 0427 025007
