Going bush
Jmac
Bike: Beta Rev3 '07
Going bush
Post by Jmac »
G'day everyone,
I'm heading to the bush this weekend and taking the trials bike with me for the 1st time....
Any ideas on the most suitable tyre pressure for the state forest?
(I'm expecting it to be very wet and muddy in some areas)
2IC
2IC
Bike: Beta EVO
Re: Going bush
Post by PA »
6 psi in the front and 4 psi in the rear tyre is normally a good base point. Going for a general ride you could run and extra 1 or 2 psi if you felt the need.
paulm
Club: Wollongong MCC
Bike: BSA Bantam
Re: Going bush
Post by paulm »
PA is on the money re pressures. Depending on how your carby is set up, If you intend to do a lot of quick 'trail type' riding you might want to think about richening the mixture a bit too.
Jmac
Bike: Beta Rev3 '07
Re: Going bush
Post by Jmac »
Thanks for the replys!
I don't think we'll be flying down the trails but a bit quicker than what we usually do down at Oakleigh.
At least until we find a spot to play!
paulm
Bike: BSA Bantam
Re: Going bush
Post by paulm »
Just listen for it 'pinking' when you open the throttle while flying along - if it does open the choke for a bit :)
Jmac
Bike: Beta Rev3 '07
Re: Going bush
Post by Jmac »
Excuse the ignorance paulm.... what does pinking mean?
I assume, Open the choke to give it a bit of a richer mix?
Jmac
Bike: Beta Rev3 '07
Re: Going bush
Post by Jmac »
I tipping just a typo and you meant pinging
Will do!
Re: Going bush
Jmac wrote:I tipping just a typo and you meant pinging
Will do!
"pinking" and "pinging" are both commonly-used terms for the same condition
