TY 250 B reed valves
GSX 1300R
- Club: Shoalhaven Classic
- Bike: 1975 Yamaha TY 250 B
Installed Hi Tech carbon fibre reeds to ty250b They don't want to sit flat on rubber sealing surface Can I remove rubber surface and fit them ? Any advice would be much appreciated cheers
Re: TY 250 B reed valves
There was discussion on this subject a few weeks ago on Trials Central. One person said that back in the day they used to carefully remove the protruding rubber when they fitted composite reeds, but didn't remember how they did it.
I bought Boyesen dual stage reeds for a TY250 motor many years ago but was not happy when they didn't sit flat, because of the rubber pushing on them. I rode it like that for a while then refitted the standard reeds and later gave the composite reeds to a friend.
The protruding rubber should be able to be removed and leave a smooth flat surface using a surface grinder, taking fine cuts and using coolant. Another method would be to attach a sheet of fine wet and dry abrasive paper to a very flat surface and water to keep the rubber particles from clogging the wet and dry.
GSX 1300R
Thank you David For now I have refitted OEM reids which sit flat I have a spare C model reid block which I am thinking of modifying as your suggestion cheers
