2019 Scorpa 250 clutch drag
Posted: Sun Nov 24, 2019 12:33 pm
I have a new Scorpa 250 racing, with an hour on the clock.
I have lost my clutch pressure. It intermittently comes and goes after a around 10 minutes of riding. I cable tied the lever to the bar overnight and it got better. Then same thing happened again
. With bike in gear and stopped the clutch will slowly start grabbing and the bike will stall.
There is no way of bleeding the clutch at the slave cylinder, is this normal for a new trials bike? Never had a problem with enduro bikes doing this.
Closest dealer for a warranty is 2.5hrs away. I'm told they can get air in them from freighting, also there wasn't much fluid in the resivior when I started to work on the problem.
Was it possibly low or empty from build? Also seeing small gold speckles in the resivior.
Has anyone experienced this?
Located in Victoria.
Any info is greatly appreciated.
