TY175 Right side crankcase
Posted: Mon Jul 13, 2020 7:16 pm
by wil
Hi all. I'm needing some help & guidance from this awesome Forum here. I have been toiling away at getting my TY175B going after sitting idle for three or so years. So I've cleaned the fuel tank of old fuel & got ride of the rust, installed new points, coil, carby kit hoses & air filter. so after some fiddling & guess work it fired up & runs well but the clutch had a few problems as explained in another post ( jumps when put in gear & won't totally disengage). so I pulled the clutch out cleaned it, emery papered the steel plates measured the friction plates which are still ok as were the springs. couldn't get the push rod & ball bearing out not matter what I did. Tried grease on the end of an allen key, magnet, air pressure, flooding it out leaving on its side for a good while hoping gravity would get it out but no go. :oops: :x :shock:
Anyway I put it all together went to put the sump plug back in only to find it had stripped out :x , only to find the raised sump plug section (at sometime under previous ownership) has had a half of it break off & had been JB welded. :cry: :cry: . So Im not keen ATM to strip it down as I would love to get a bit of riding out of it then do a rebuild. so if any one has any ideas all brain storming welcome . Also if anyone has a Right side crank case they don't mind selling please let me know. I have had a suggestion of stripping it & have a block welded on & re drill & tap the hole but if I'm going that far I would rebuild the engine I think.
cheers
Wil
Re: TY175 Right side crankcase
Posted: Mon Jul 13, 2020 7:37 pm
by Twinshock200
Hi Wil
Sorry to hear of your problems but I can help with the crankcase right hand side.
I have several sets of Ty175 crankcases and I can either sell you a right hand or you can buy a matching pair.
Let me know, either on here or message me through the private message system.
Galps
Posted: Mon Jul 13, 2020 7:55 pm
Will you can permanently glue in place the drain plug and next time you want to drain the oil just loosen off the clutch cover screws and open the joint a bit. Be careful with it and you'll even get away with reusing the same gasket. If not they are easily available and cheap.
Posted: Mon Jul 13, 2020 9:47 pm
by wil
Thanks for the replies Galps & David. I'm thinking of giving a helicoil a go first & if that doesn't work an oversize piggyback sump plug, That's a plug inside an oversize plug so you can still drain from the plug. But an intact crankcase would be in the pipeline too.
cheers
Wil
