Hi all, I'm working through a few issues on a cota 247 that I've had in storage for a while. The latest is a stiff/non-returning gearshift. I'm going to pop the cover off and have a look, but thought I'd ask if there was a common issue I should be looking for?
Cota 247 gearshift
Re: Cota 247 gearshift
Stiff usually means the shifter shaft is bent or there is something wrong with the alignment of the hole through the cover
Possibly. I just went to drain the oil, checked the shifter and it's freed up? Maybe something to do with engine heat?
Problem solved. Turns out the clutch drain bolt is just long enough to bind on the gearchange mechanism if you use too thin a washer
- Hagsta
- Club: SQTA
- Bike: Montesa300RR
The gear shift on my 247 also had a tendency to stick and after reading this I tried an extra fibre washer on the drain plug.....
the bike is now shifting cleanly and the sticking is no longer an issue!!
I love it when you come across a simple fix to an otherwise frustrating problem
