i bought some of the recommended oil for my 2000 cota(ELF HTX740). the amount to go in is 550ml but i was wondering if 500ml would be enough for it to work the same. the bottle is a 2 litre and i wanted to get as much use as i could cause it's rather expensive. i have heard that a bit less oil is sometimes better and isn't a problem with the workings of the clutch.
andrew.
montesa cota gear oil amounts
