Montesa ECU Map
2IC
2IC
Bike: Beta EVO
Montesa ECU Map
Post by PA »
Mild clubmans map from Ferret Flasher on Trials Central.
This post is more of a test to see if this works ok.
zog3.e2p
(781 Bytes) Downloaded 547 times
Phoenix
Montesa ECU Map
Post by Phoenix »
Hey there, PA if you want to know if the test is successful and if it works,
Well the answer is yes it does.
I downloaded it and opened up my Program and everything is A-OK
if you want some more Programs just tell me how you put them across the net so I can do the same
I've got Three major Programs that I was given
so if you interested give me a TXT
Frank van Heerden
VIVA MONTESA
Rob W
Post by Rob W »
Ooooo this sounds like interesting gadgetry. Will someone hurry up and buy my house so I can join in too. :mrgreen:
But guys - isn't buying a Repsol 4RT and then programming a mild clubman curve a bit of a waste :?:
Rob
Ca plane pour moi
jmclean
Bike: Montesa
Post by jmclean »
Rob, the only waste with a Monty is not riding it !! :wink:
Rob W
Post by Rob W »
jmclean wrote:Rob, the only waste with a Monty is not riding it !! :wink:
Touche!
Rob
Ca plane pour moi
2IC
2IC
Bike: Beta EVO
Re: Montesa ECU Map
Post by PA »
Phoenix wrote:Hey there, PA if you want to know if the test is successful and if it works,
Just post in this topic or start a new one and attach the file.
Ferretflasher
Post by Ferretflasher »
Ok Monty people, I have written some programs for the 2-map PTB and will happily email these out to anyone who needs some maps to begin playing with. I have written these to suit my riding style and so dont expect everyone to find them to their liking. You MUST have the 2-map software to load these maps, the 1-map and 2-map software are NOT interchangeable, so you cant mix them together.
Final note, for sustained high speed road work, you MUST use switch position 2 ( ie map #2) , the other has too much fuel removed and would run very lean with possible damage to the valves. By sustained high speed, I mean in excess of 60-70 kph.
You will not notice much difference when playing about in the garden/back yard but in big-power full mashing sections, you will feel the difference! :mrgreen:
m1mild2.e2p
(756 Bytes) Downloaded 372 times
m2wild2.e2p
(850 Bytes) Downloaded 416 times
KTMSprocket
Post by KTMSprocket »
So you guys can write a program, write a new map...upload and test.
I can't get KTM to acknowledge they have and efi problem (990adv) yet alone get this far!!!!
Sydney, Australia
seiko
Club: RTC
Bike: montesa repsol 4RT
Post by seiko »
So..... Rob... Gonna get an ECU for your new Monty?? ;-)
Club: TCC
Bike: 06 Sherco 250
Post by Neo »
No, I think Rob prefers to adjust his use of the twist grip...just like me :P
Hey Rob...you jumped ship?
Best of balance.
