TY175 Poor starting & running probs
Posted: Sun Feb 04, 2007 1:04 am
Hi again,
Thanks to Austini letting me borrow bits off his recently refreshed machine (that looks absolutely fantastic), I could now problem solve my bike further, but still not to any conclusion, your help please.
I got hold of a flywheel puller, revealed points and condenser to be in good condition (looked fairly new), cleaned anyway. Replaced flywheel and checked gap ok. Have new plug also.
Using Austini's carby, it started not easily (with choke), but better than my carby, then off choke. When getting to run needed a few more revs to 3/4 to keep running. For about 30 secs its sounds ok, then starts to misfire and more so under more revs. (done this every time it starts)
Pull plug to reveal not too wet, but black coating from running. Not much smoke from exhaust, but a puff when misfires.
Used another HT coil, same prob.
Disconnected kill button also, still the same.
Having previously checked reeds and manifold for leaks, is it sucking air leaning mixture; fuel starvation; elec prob still; or the worse outcome - crankcase leak via base gasket or engine seals?????
Any tips here to prove the above further?
Thanks Roger
Thanks Roger
