I have a kroo 249 and the clutch slips in the higher gears.
Are they adjustable or likely to be worn out?
If worn out, does anyone know how hard fibers are to get?
Also what year's did kroo's get built?
Fantic clutch
- Phil
- Club: TCV
- Bike: GasGas
Kroo Clutch plates
Hi
I brought some clutch plates for a Kroo off Mal Loone at
GasGas Motos he had to order them.
Mal's number is 03 52295464.
Thanks Phil
Thanks Phil
motocentral
- Dealer
Fantic clutch plates
Hi crazyfast
We have clutch plates in stock in Canberra for the Fantic K-Roo's.
Drop us an email or ring if you want them in a hurry
ph: 02-62480229
email: [email protected]
http://www.trialzone.com.au
ph: 02-62480229
Play with Gravity
Hi I have a 303 and it had clutch grab when I bought it so I dumped the oil and fed it some new 5 to 15 weight and It still grabbed but also now slipped in higher gears. I dropped the clutch pack and found that the clutch plates and the friction had a glaze on them. Aremed with some 180wet and dry I gave them a quick deglaze on a piece of glass (read daughters window) and after slappimg it back together found it had no more grab and no more slip. I can even find neutral whilst its cold. It might be worth the shot before replacing plates
Dave
Dave
