The Trial is off the road which essentially joins Collector with Gundaroo - but really close to (only a couple of kms from) the Gundaroo end.
The trial's entrance is off Wurungul Lane off Marked Tree Road.
There are several ways to get there from Goulburn.
The way you indicated via Gunning... turn left just after the bridge before you actually get into Gundaroo proper (street sign says Collector 24k, to Marked Tree Rd & Waste Depot)
You can get there by turning off the Hwy at Collector (making sure you then turn left shortly after) & keep heading towards Gundaroo..
The road is unsealed for a fair bit but becomes tar again at the Gundaroo end. You turn right into Wurungul Lane (signs posted) after which it's 700m to the property gate on the right.
Otherwise, head down the Highway and make your way to Gundaroo (on the sealed roads) and again, follow the signs off Marked Tree Road into Wurungul Ln.
If this is still 'clear as mud' - contact me by phone
Phantom wrote:You can get there by turning off the Hwy at Collector (making sure you then turn left shortly after) & keep heading towards Gundaroo.. The road is unsealed for a fair bit but becomes tar again at the Gundaroo end. You turn right into Wurungul Lane (signs posted) after which it's 700m to the property gate on the right.
Thanks Dennis,
Ok if I have this right it should look a bit like this?
