Page 1 of 2
Fantic section carburation
Posted: Fri Nov 02, 2007 7:12 am
by fulmine
Hi all, maybe some one could help me and my '95 Fantic Section 250 cc.
What's up: when the bike and the carburetor are foreward inclined (rear wheel upper front rear) the carburation at the idle became lean, when the bike isn't inclined the idle is ok with right carburation. The carburator is the Dell'orto 26 PHBH CD.
Have a idea?
Thanks of all.
Posted: Fri Nov 02, 2007 8:22 am
by Neo
Hi fulmine,
That’s still the same carb they use on many modern trials bikes.
Start buy giving the carb a good clean out with compressed air....and see how that goes.
But I'd guess you have trouble with the floats (starting to sink) or the float needle is worn.
I used to own a 95 Section. Last I heard it made it's way to back to VIC....where abouts are you?
Best of balance.
Posted: Fri Nov 02, 2007 8:20 pm
by fulmine
Thank you Neo,
the carb is very clean, the air filter too, the plug is new, and the mix is 100:1 with synthetic oil, when I taked apart the carb to clean up I check the float and apparently it was ok (no liquid inside). On your bike which float weight there is?
I'am from Italy the Country of the Fantic and Beta, The new Fantic brand isn't the same of the '70 original Fantic, a guy buy the name, but he produce and sell only enduro Bike 50 and 125 cc, no trial.
Bye.
Posted: Mon Nov 05, 2007 8:15 pm
by Neo
Hi fulmine,
I've never seen a float weight on any carb I've worked on. If you can remove it, do that, then try staring on a foreword incline.
Ahhhh....Italy
....Once the home of my parent.
Do you have any information about the new Fantic Trials Bikes? I am very keen to know what they producing now?
Best of balance.
Posted: Mon Nov 05, 2007 8:55 pm
by fulmine
No trial bikes from the new Fantic at the moment. They produce only kynd of enduro bikes and a cofee machine!
You can see the new model at
http://www.fanticmotor.it
About the carb, what I looking for foreword incline?
Posted: Wed Nov 07, 2007 6:35 pm
by fulmine
What do you meaning with "staring"?
Posted: Thu Nov 08, 2007 8:24 am
by Neo
Sorry fulmine,
I ment "Starting".....just a typing mistake
Best of balance.
Posted: Fri Nov 09, 2007 2:48 am
by fulmine
I could try it, but i'm sure with out float the carb doesen't work, the mix surge throught the jets by the level of the mix in the tank.
Posted: Fri Nov 09, 2007 7:14 am
by Neo
fulmine wrote:On your bike which float weight there is?
Hi fulmine,
I thought you were saying that there was a weight on the float. But maybe I have read this wrong?
You are right....do not run the carb without the float. Because petrol will be coming out everywhere
Best of balance.
Posted: Tue Nov 13, 2007 9:09 pm
by fulmine
Have someone experience with mikuni 26 vm on fantic section 250 cc ?
