Backward Bultaco is it true???
Posted: Wed Apr 02, 2008 3:40 pm
by BJ
This is reply post I got from another forum-
I remember an old Bultac Sherpa-T that I owned. Lot of fun on that. My brother was mucking around one day and pushed the bike with me on it backwards. I dropped the clutch the bike strted, and proceed to kill myself as all the gears were operating in reverse !!
After practice we managed to do this on call and managed to ride the bike quite successfully in reverse gear. Made the neighbours sit up and look !!
Is it true? Can anyone out there ride a bike with a motor running backwards?????
Re: Backward Bultaco is it true???
Posted: Wed Apr 02, 2008 5:20 pm
You can do anything with practice - haven't you seen what Christian Pfeiffer can do on a motor bike?
What's the difference between that Bultaco story and when we used to be allowed to roll backwards without penalty in trials sections? Stefan Merriman was quite good at it at the time. I have only done it successfully for a couple of bike lengths as a lark but I'm sure there are many people who incorporate it in their riding practice.
I think if you had to face rearwards on the bike as well as travelling backwards it would be a bit harder. My kids can do it (ride backwards facing backwards) on their off-road scooter quite successfully downhill so it would probably just be a matter of learning to use your left hand for the throttle on a motorbike.
Posted: Wed Apr 02, 2008 5:59 pm
by PA
Rob White does it. At Glenmaggie he started his bike and it was running in reverse direction and managed to ride backwards then get the motor to start running normal and did it all without footing. Bloody show off.
Posted: Wed Apr 02, 2008 6:39 pm
by motodevo
most 2 strokes will do this, due to the timing being only a degree or two from top dead centre. I had a scary experience fixing up and old dt175 for my mates missus, the stator was stuffed so we swapped it for a later model one i had lying around, bike started first kick so i clicked her into gear and dropped the clutch with a handfull of throttle and she roared off .....backwards!!!!
Seemed the later model stator plate has windings that are tweaked around about 5 degrees. After we put the new windings onto the old stator plate, neither of us wanted to test ride it.
Atleast the dint in the garage door was easy to pop out.
Posted: Wed Apr 02, 2008 7:56 pm
by Stu
Yep it's TRUE! My old Sherpa T did it to me once. Scared the hell out of me as well. After cleaning the points, I tried to start it and it let out a cannon shot that echoed thru the valley when it back fired!
After a couple of minutes I dared tried to start it again. This time it proceeded to head for the fence backwards. I hit the kill switch real fast and kicked it into life again. Ok, it started and it was running the right way finally.
It never did it to me again, and I was very careful doing the points also...
Posted: Wed Apr 02, 2008 10:33 pm
by JetLag
Tried to ride an old yamaha 100 ag bike up an irrigation drain, stalled half way up and used the clutch as a brake going back down backwards (other brakes didn't work), ended up halfway up the other side on my arse when the motor fired up in reverse
Posted: Mon Apr 07, 2008 10:39 am
by richardr
Over 30 years ago, I saw a Bultaco sidecar outfit attempt a steep climb, just as the bike was about to clear the top, it ran out of puff, stalled for a fraction of a second and then re-started BACKWARDS with the engine running full-throttle, because the rider still had the throttle wound right out.
The bike and 2 passengers shot back down the hill then the bike cartwheeled and a footpeg speared the passenger in the upper thigh. nasty wound, but it could have cut his femoral artery and he would have bled to death.
I made a mental note back then, not to ever ride a Bultaco.
Posted: Thu Apr 24, 2008 5:27 pm
by colin jay
Richard,
Back in the early 80's while competing (in South Oz) with a 350 Bully outfit we did pretty much as you describe while riding a steep climb in a section. All who saw it happed though it was quite entertaining.
We used to run with the ingition time advance a few degrees more than it should be, and found that if we got the engine to almost stall, them clutch'd it, it would run backwards. We actually rode between a few sections in "reveres much to the enjoyment of the other riders and spectators. The outfit handled like the preverbialy PIG going backwards though.
During the 70's I saw the same thing happen numerous times with the mate,s Yamaha RT2 360. Watching a guy "nut" himself as his bike shoot backwards between his legs will always be funny and would probably earn you a few dollars from Funny home videos now days.
Colin
Posted: Thu Apr 24, 2008 6:24 pm
by gasman
My brother managed to get his 06 sherco to run backwards. The weird thing is that he was rolling down a hill kick starting it? very funny he s%^t himself.
